Replacing engine mount
Old Feb 5, 2019 | 08:38 AM
villemiami's Avatar
Default Replacing engine mount
Today, I brought my car to the garage to check the engine mount. He told me that we need to replace the 3 engine mounts: front, back and transmission, and it would cost $810.
He opened the hood, and **** the gear to back, then I saw the engine tilting.
He showed me the front engine mount, but didn't lift the car to show me the other 2 mounts.
Do we really need to change all 3 mounts? or only the front one?
Old Feb 5, 2019 | 04:36 PM
Default Re: Replacing engine mount
Not sure what you're talking about "front" and "bottom two". There are 3 mounts: bottom, left and right. The left and right support the entire weight of the engine/CVT. The bottom prevents torsion.
If the $810 is the price for genuine Honda parts, it's a good deal. If he's using aftermarket parts, he's making a lot of money off of you.
Both of my HCH2 needed all mounts replaced.
EDIT: A common indication of the need for replacement mounts is vibration when in "D" and stationary. This typically goes away when you're driving.
Old Feb 5, 2019 | 08:25 PM
villemiami's Avatar
When I'm at the red light in D, I don't feel vibrations. In 2 oil changes at 2 different locations, they told me about the engine mount.
When I went to the garage, he started up the car and put the gear to backward, and I saw the engine tilting front and back. I also saw the front left mount moving as the engine was moving.
He said that the price was for dealer parts.
Can I use aftermarket engine mounts or does it have to be Honda?
Old Feb 5, 2019 | 09:12 PM
If the rubber is visibly cracked, they should be replaced. I used aftermarket.
The engine tilting front and back is likely the lower brace. That one is cheap and can be replaced in about 10 minutes. I would try that first.
https://www.hondaautomotiveparts.com...-engine-mounts
Parts 4, 5 and 7. You should be able to find a very cheap aftermarket torque rod:
Amazon Amazon
Engine side mount:
Amazon Amazon
CVT side mount:
https://www.amazon.com/MTC-1010882-50850-SNC-A91-Transmission-Mount/dp/B016S1DURY https://www.amazon.com/MTC-1010882-50850-SNC-A91-Transmission-Mount/dp/B016S1DURY
Old Feb 6, 2019 | 09:42 AM
villemiami's Avatar
Thanks, I will choose aftermarket then.
Old Feb 11, 2019 | 08:22 AM
villemiami's Avatar
I found another garage who will replace 1 Honda mount for only $150. Then, he told me he'll see if we need to replace another mount. That's cheap compared to the previous garage who would replace all 3 mounts for $810. I think garage price depends wether if it's located in an expensive or poor area. I don't mind going in a poor area for my car as long as I don't live there.
Old Oct 7, 2019 | 04:10 PM
Tom in Austin's Avatar
Change all three, if one's bad the others are on the way. BTW, this is not a terribly hard DIY job if you remove the plastic underbody panel and use a floor jack with a block of wood to raise/support the engine while you change each mount. The one on driver's side is harder because there's a lot of stuff above it that has to be disconnected and moved out of the way.
The torque strut underneath is easiest of all, two bolts into the bottom of the engine and one big one that attaches it to the crossmember.
mulletman13
Apr 25, 2017 03:50 PM
mcfejoc
Apr 28, 2016 09:36 AM
Macwill22
High Mileage Vehicles
Dec 11, 2014 04:38 PM
hybrid-theory
Jul 11, 2014 11:55 PM
ekpolo23
Apr 22, 2014 11:23 AM
