PA0E1 and P1448
Old Sep 5, 2021 | 10:26 AM
pradheepsh's Avatar
Default PA0E1 and P1448
Hi
i had P1448 error and one the hybrid technician replaced the hybrid fan and when the lights came back again was suggested to replace the hybrid battery .
Now that the hybrid battery is replaced with a new battery , i am seeing POAE1 the very next day ?
Also when it was diagnosed earlier it had 61-01, 61-21 61-01, 61-23 ? and B2989 codes.
ALso the main 12V battery was replaced last october by AAA 151R battery.
I am at my wits end with this car. Can this be related to main battery or connector ?
I have already spend 3K on this car and i am at the point of giving up .
Except the code coming up . there is no problem with the car and it has around 90K miles on it
Any help would be greatly appreciated.
Old Sep 5, 2021 | 10:52 PM
Default Re: PA0E1 and P1448
P1448: Bad Fan or Bad BCM
61-01 - Not valid
61-21, 23 - Short in the drivers seat belt buckle switch
P2989 - problem in the A/C compressor motor - Intermittent, Bad #22 fuse, bad A/C compressor
P0AE1 - Bypass contactor malfunction - bad DC/DC converter, Bad IMA battery (contactor), Bad BCM, Bad MCM.
Diags for P1448 and P0AE1 are very involved with each having over 30 steps. I suspect your "hybrid technician" just guessed.
Old Sep 5, 2021 | 11:40 PM
pradheepsh's Avatar
So can i drive the car for short distances, since the only thing that comes on is IMA light ?
At this time i am not worried about the new battery going bad too as i suspect i cant get any refund now.
Old Sep 6, 2021 | 07:56 AM
If you experience no other adverse symptoms, probably.
Jschoenherr
Jul 17, 2018 03:08 PM
