Recommended oil?
Old Oct 16, 2008 | 06:54 AM
  #31
skoh's Avatar
Site Sponsor
Default Re: Recommended oil?
Originally Posted by jg013c
$44 seems like a good deal for a 0W-20 change. My local shop wants $70 for the oil change. Figuring $7 a quart and 5 quarts of oil, the oil alone will cost the shop $35. I do not see how they can do it for $44.
Around here a non-synthetic oil change normally costs $35 or so.
I agree. I can think of a couple of reasons:
1. The oil change is a loss leader to get the customer in the door.
2. The dealer may be able to save on the oil by stocking in bulk vs. quarts
Old Oct 16, 2008 | 07:04 AM
  #32
jg013c's Avatar
Or that $44 "0W-20" oil change may actually use a non-synthetic oil that is not 0W-20.
Old Oct 16, 2008 | 07:20 AM
  #33
skoh's Avatar
Site Sponsor
Generally 0W-20 requires at least a Group III base oil which is considered synthetic in the United States.
And I hope that it would meet the appropriate API approvals.
Here is a list of API approved 0W-20:
http://eolcs.api.org/FindBrandByVisc...iscosity=0W-20
Old Oct 21, 2008 | 07:53 PM
  #34
JoeRemix's Avatar
I noticed a few of you change your own oil but buy the factory filters. Is there a reason you do this?
I've been thinking about doing the Mobil 1 0W-20 Advanced Fuel Economy and was considering using a Fram filter, any thoughts or suggestions?
Old Oct 22, 2008 | 05:43 AM
  #35
GeorgiaHybrid's Avatar
Joe,
Take a look at the BITOG site http://www.bobistheoilguy.com for some informed opinions about Fram filters. In general terms, some of them are OK a lot of them are marginal at best.
Most of the recommended filters are Mobil 1, Wix, Napa Gold (same as Wix), Puralator Pure One, K & N, Amsoil or similar filters (factory). I happen to use Mobil 1 or Wix for oil filters and Wix for my cabin and air filters.
Fram air filters seem to work fairly well and a lot of people use them as well as the Wix and Puralator filters. I will not get into the hype about K & N style oiled air filters but you can also go that way if desired.
Old Oct 22, 2008 | 11:27 AM
  #36
JoeRemix's Avatar
Thanks for the reply!
My dealer's service center uses Castrol Syntec, I usually get a coupon for about a $30 oil and filter change. Never inquired about what oil they're actually putting in my car.
Two questions: what do you think about the Castrol vs. Mobil 1?
and
Would it be worth it for me to buy the Mobil 1 and have them put it in my car (since I'm not ready, especially with winter approaching to DIY, yet)?
I've looked around locally and haven't found the 0W-20 Mobil 1 anywhere except Pep Boys ($6.69/qt).
Old Oct 22, 2008 | 03:05 PM
  #37
This one usually starts a firestorm on that other board.... Pennzoil Platinum, Mobil 1, Quaker State Advanced, Castrol Syntec or any other major brand of synthetic oil will be fine with a 5,000 mile OCI. To be honest about it, any major brand of dino oil will work given a 5,000 mile OCI..... The only problem is that 0w-20 is only found in synthetic while 5w-20 can be had in either flavor.
Old Oct 22, 2008 | 04:26 PM
  #38
ekpolk's Avatar
The Regenerator
Joe:
I'll second David's recommendation that you check out BITOG (especially since I'm an admin over there myself... ). Seriously though, you'll find much good info.
I don't use the OEM filters. I'm sure that they are just fine, but I've done UOAs with particle counts, and brute force filter dissections on various brands, and I prefer others. I especially don't care for the construction of the Fram filters. The filter medium is secured on the ends with flimsy and poorly glued cardboard end caps. On an appropriately sized Fram model, you can literally crush the entire filter element, including the very thin metal center tube, with your bare hand. Filters like the NAPA, and all brands made by Champion Labs (Mobil-1, K&N, STP, some Bosch, and various house brands), the filter medium is very strongly cemented into strong metal end caps, and the element/cap combo, hand-crushable in a Fram, is indestructible unless you get at it with heavy tools. Toyota OEMs have cardboard end caps too, but when examined closely, they are much better put together than a Fram.
Now, certainly, I don't think that Frams are failing by the droves, but since their prices are essentially the same as for any number of much more robust filters, I'd just as soon pay for the better made filter. Both our TCH and the Prius are presently wearing NAPA 1396s.
Old Oct 22, 2008 | 04:31 PM
  #39
ekpolk's Avatar
The Regenerator
and
Joe:
The Autozone stores in our area carry M1 0w-20 AFE for 20 cents less per quart than PBZ does. This stuff should work just great in the TCH. You might also consider Pennzoil Platinum 0w-20. Only drawback to the PP is that it seems to be almost an unseen animal in the wild (as in on store shelves). I just ordered four cases from an on-line store, and even with shipping, the per-quart price is, IIRC, $6.35, actually slightly less than M1 from the local AZ or WM.
Old Oct 22, 2008 | 04:33 PM
  #40
chris_h's Avatar
Originally Posted by skoh
Toyota recently announced that they are moving to 0W-20 across the board.
In the July 1, 2008 Edition of Flashpoint, ILMA has announced that Toyota has officially decided to switch the recommendation on engine oil for certain vehicles from SAE 5W20 and SAE 5W30 to SAE 0W20.
ILMA reports that these changes will affect all Toyota brands, including Toyota, Scion and Lexus. The change will also appear in owner's manuals.
Please read more about this announcement here:
http://newsmanager.commpartners.com/...8-07-01/1.html
Here is a link to download the TSB:
http://www.chrysanindustries.com/pdf..._tsb071002.pdf
Neither of those links work for me. I think I will need the TSB because my dealer wants to charge me extra for the 0w20 (over the prepaid maintenace fees).
