ecm swap help!!
Old Oct 20, 2022 | 03:33 PM
???'s Avatar
Default Re: ecm swap help!!
the outputs might look a bit funny because it's a 3 phase probably square wave if I had to guess to a brushless motor.
here's a quick pic of what I see for wiring at the module. the tab wire labeled fluid pump is running to pin 41 of the ecm, the light green wire called pump control is also running to the ecm pin 5. I think one tells the module what speed to run and the other is reporting the speed back to the ecm to make sure its working. my guess is a pwm signal. your scanner may have a scope built in, or if you have a meter with hz it might show you something if it's sending a signal.
I have no idea if any of the other codes are keeping it out of auto stop or if that matters.
oh and key on, I think you should have power at 2 pins on the input side? one the thick all the time wire and one key on, probably much thinner.
Old Oct 23, 2022 | 02:40 AM
Tahoe_08's Avatar
i'm wondering if corrosion is an issue in all of this a few people reported unplugging the wires several times fixed the issue for them
Old Oct 27, 2022 | 05:46 AM
dnt1010's Avatar
Diagnostically high level sophisticated thread... may need sling-blade to stop by and take a look!
Dustinlint
17
Nov 18, 2022 06:48 AM
Dustinlint
26
Oct 10, 2022 05:05 PM
Pombal
Feb 8, 2018 09:48 PM
Neil
Sep 28, 2006 12:46 PM
rigger
Honda Insight
Aug 28, 2005 08:04 AM
