wiring question??
Old Jul 3, 2006 | 01:23 PM
jmorton10's Avatar
Default wiring question??
I will be installing an Eclipse in dash GPS/NAV unit in my 05 FEH shortly(I'm waiting for it to arrive) & it needs a connection to the speed sensor wire.
Does anyone have a wiring diagram that shows where this wire(location/color code etc)is located???
TIA,
~John
Old Jul 3, 2006 | 02:26 PM
dsd's Avatar
dsd
Default Re: wiring question??
Sorry, I can't help but I do have a question:
Whay does a GPS system need a connection to the speed sensor? Every GPS I have used tells speed naturally as they are a GPS System.
Just curious,
dsd
Old Jul 3, 2006 | 02:45 PM
jdenenberg's Avatar
Engineering Professor
John,
Audiovox makes a speed pulse detector ($30) that should work. New cars have this info on the CAN bus (ODBII) so there is no analog speed pulse wire. The audiovox unit(s) use a magnetic detector like those on the old add-on cruise control systems to generate the required pulse.
http://www.sjgreatdeals.com/avx2504165.html
http://www.bnotions.com/SPEED_PULSE_..._p/2504165.htm
There is also a CAN bus interface that will generate such a pulse, but it is expensive ($200) and requires a good installer.
http://www.soundgate.com/index.php?r...&usereferrer=1
I found these on the web by using Google - eclipse "speed pulse"
JeffD
Old Jul 3, 2006 | 02:48 PM
jdenenberg's Avatar
dsd,
I had the same question so I went to the Eclipse site. They seem to use the speed pulse (after calibrating it via GPS) to get a more consistent reading on MPH.
JeffD
Old Jul 3, 2006 | 03:04 PM
jmorton10's Avatar
I have no idea why it needs it, I have three other NAV units & they don't need any "speed connection" hookup. I do know the Eclipse will operate with out it hooked up so I'm not real worried about it.
~John
Old Jul 4, 2006 | 02:52 AM
jmorton10's Avatar
I found the info I need.
~John
Old Jul 4, 2006 | 04:06 PM
Tim K's Avatar
I believe that (like the factory unit) it can use speed info to maintain fairly accurate location if you lose satellite connection for some reason.
Old Jul 5, 2006 | 10:00 PM
It needs the VSS wire for two reasons:
To "guess" where you are in tunnels ( real or urban, like downtown Chicago ) or when you are in Mountain valleys, and much of the sky is blocked.
( A good thing )
The second reason is to lock out ( prohibit ) some functions while driving.
( A bad thing )
Old Jul 6, 2006 | 04:11 AM
jmorton10's Avatar
( A good thing )
( A bad thing )
I had a feeling it was to "lock out" some functions while driving. I really don't care if it loses reception in a tunnel, I think I will try it out first without connecting that wire......
~John
us035976
Oct 15, 2012 03:03 PM
rperla
May 23, 2011 07:46 PM
jmorton10
Dec 9, 2010 08:29 AM
hiram6
Jun 21, 2005 06:03 PM
curmudg
Apr 14, 2005 05:45 PM
