Engine block heater (41H)
Old Nov 25, 2008 | 12:57 PM
  #51
DesertDog's Avatar
Default Re: Engine block heater (41H)
Originally Posted by wwest
You should keep in mind that "starting" any hybrid with the engine already artificially preheated might result in foreshortening the catalyst warm up cycle and thereby result in premature failure of the catalyst, 70,000 miles instead of 150,000.
There is no way an engine block heater could possibly harm a catalytic converter. In fact, it is just the opposite. An EBH will reduce the time to go closed loop, which reduces the amount of CO and HC the cat sees from the rich mixture, extending the lifetime of the catalysts inside. In the Prius, they store hot coolant in a 'thermos' and pump it through the engine before a cold start. The only disadvangtage to an EBH is the electricity used and the possibilty of driving off while forgetting to unplug it. For fuel economy, emissions, vehicle longevity, etc. it is all good.
Old Nov 25, 2008 | 06:54 PM
  #52
Ditto to what he said.
Old Nov 25, 2008 | 07:22 PM
  #53
wwest's Avatar
Exactly my point, the system may go to "closed loop" before the catalyst is "ready".
And since, for the Prius, that is an integral part of the factory design the catalyst warm-up period will allow, adjust, for it.
Maybe....
But no one will really know until enough EBH aftermarket equipped hybrids reach ~100,000 miles.
Old Nov 25, 2008 | 07:25 PM
  #54
Unhappy Re: Engine block heater (41H)
Willard, that means you should never re-start your car after going to the store until it has had many hours of cold soak time, right????
Just think, all those dumb people out there starting a pre-warmed engine from driving their cars! Geeeezzzz...... Bet you've done this!
Old Nov 25, 2008 | 07:39 PM
  #55
"before the catalyst is "ready"
Your definition of "ready"? Better yet, reference?
Old Nov 26, 2008 | 06:57 AM
  #56
08MMHybridHappy's Avatar
Carl, John & Billy. Thank you for the re-assurance. I hope to have the parts Fri or Sat so I can install this weekend. As always, I appreciate your wisdom and your willingness to share it!
Old Nov 26, 2008 | 09:30 AM
  #57
wwest's Avatar
And here I thought I was being BRILLIANT (precluding the above statement) in using the term "artificially preheated"....
Old Nov 27, 2008 | 10:16 PM
  #58
Lone Ranger's Avatar
I think I will do the install since there is a difficulty level of 10, . Can anyone tell me if the hex key plug is on the radiator side or the firewall side? Also does anyone know how Ford runs the wires? I'd like for it to look factory.
Old Nov 27, 2008 | 10:45 PM
  #59
I thought I had photos and directions somewhere, maybe even posted on this site... in a word or .pdf document... it was about 1 year ago I did mine. Do a search and I will too and let's see who finds it first!
Not my photos, but a good one to read:
https://www.greenhybrid.com/discuss/...ns-phev-15073/
Old Nov 29, 2008 | 10:36 AM
  #60
trekwars2000's Avatar
Is this the only way (and best way) to get an engine block heater on the FEH? I have a 2008 and am looking to install one. I just don't know if it is worth it when morning temps in the winter months only get into the low 30s and high 20s.
