2011 Ford Escape Hybrid "Stop Safely Now"
Old Aug 24, 2023 | 03:32 PM
  #41
Ejanes508's Avatar
Default Re: 2011 Ford Escape Hybrid "Stop Safely Now"
It might be fixed now. Let battery charge a bit more and did one more pcm reset. Engine is running and not shutting off, but is running a little rough. No codes, and beyond it running rough, all seems good. Thank you for the help, will let you know if it goes back to acting up, you're a lifesaver.
Old Aug 24, 2023 | 07:00 PM
  #42
When you do a PCM reset, it can take awhile to figure everything out and run smooth.
Old Aug 24, 2023 | 07:17 PM
  #43
Ejanes508's Avatar
Took a drive around the block, got some codes for random misfires, but I imagine that's just pcm related. Cleaned all the spark plugs and cleared codes. Otherwise, the car is back to the way it was. Thank you again for your help.
Old Aug 24, 2023 | 08:31 PM
  #44
Glad to hear it. Coils can also contribute to misfire. If you haven't replaced the plugs, or they aren't the long life iridium plugs, I'd replace them.
cnwinger
Feb 17, 2023 02:33 PM
bofronado
Ford Motor Company
Oct 13, 2019 11:07 AM
KermitDFrog
Nov 17, 2018 03:47 AM
