Ford Motor Company Ford, Mazda and Mercury hybrids
05 Escape Hybrid "stop safely now" only in hot weather
Old Oct 11, 2019 | 12:27 PM
bofronado's Avatar
Default 05 Escape Hybrid "stop safely now" only in hot weather
Just throwing this out here to see if anyone has a clue what to try next. I have an 05 Escape that was getting the stop safely now warning pretty often. I replaced the rear actuator and it got somewhat better. I looked at the coolant system pump and it looks like the newer style, and I could feel it running. I used a vacuum to suck the air out of the system, about a pint was then added. That seemed to take care of the issue, unless I am out driving the car in town on a 85-90 degree day. It will then shut down, and after a while it will be perfectly fine again. There are no error codes that I am getting with these shut downs.
Does the coolant system require flushing? I was thinking about replacing the coolant pump, thinking it might not be pumping as fast as it should. Just at a loss as what to do next.
Old Oct 13, 2019 | 11:07 AM
bofronado's Avatar
Default Re: 05 Escape Hybrid "stop safely now" only in hot weather
After thinking about this a little longer, I am wondering if these issues could be related to the temperature of the hybrid battery. The A/C on the car works, but not great, and I know that there are A/C lines in the battery compartment. This also tends to happen on hot sunny days. Does an overheated traction battery give you the "stop safely now" warning?
cnwinger
Feb 17, 2023 02:33 PM
Frank_and_Beans
Sep 14, 2012 04:50 PM
Todd G
Jan 4, 2012 05:14 AM
mes323
Jul 21, 2011 07:28 AM
liegev
Nov 21, 2009 06:48 AM
