2011 Ford Escape Hybrid "Stop Safely Now"
Old Aug 21, 2023 | 04:04 PM
  #31
Default Re: 2011 Ford Escape Hybrid "Stop Safely Now"
Since a jump starter isn't present, perhaps they're willing to hammer the battery harder.
Simply REMOVE (not just turn) safety plug when attaching power supply to jump start leads.
Old Aug 21, 2023 | 05:49 PM
  #32
Ejanes508's Avatar
I gotcha. Charger should be delivered in 2 days or so, will update when I've got it hooked up.
Old Aug 21, 2023 | 05:55 PM
  #33
Cool. Four hours max charging when from a known low state of charge.
Old Aug 24, 2023 | 12:38 PM
  #34
Ejanes508's Avatar
Charger is in and hooking it up now. Was reading through the Jumpstart thread and saw this guy's comments, it sounds exactly like what mine is doing, but I'm unsure of what he's saying resolved it. Any clue?
Old Aug 24, 2023 | 01:48 PM
  #35
4 hours max.
a link would help.
Old Aug 24, 2023 | 02:04 PM
  #36
Ejanes508's Avatar
https://electricvehicleforums.com/fo...6/index34.html
#333 and 335
Old Aug 24, 2023 | 02:23 PM
  #37
He replaced fuel pump first. Then he got a new set of codes associated with the ignition coils. I'm assuming he didn't get fuel at the rail after saying he tested it. Once he had fuel, the car sensed an issue with the coils.
We speculated he replaced the ignition coils because that was phonetically similar to the words written.
Old Aug 24, 2023 | 03:15 PM
  #38
Ejanes508's Avatar
Charged battery to where it would hold 330v without charger. Same issue, no new codes, just P1000:00-2B. Did notice what seemed to be a misfire when starting it this time around, not sure if it's related to a pcm reset I did.
Old Aug 24, 2023 | 03:18 PM
  #39
Make sure you're not reloading the same vehicle profile. Start with a fresh detect and don't save the profile.
On to plugs and coils.
By PCM reset, do you mean disconnecting the battery terminals and shorting them together for an extended period?
Old Aug 24, 2023 | 03:22 PM
  #40
Ejanes508's Avatar
No, forscan pcm module reset and all adaptations reset. No new codes with a new profile.
