Cost of Oil Change under Warranty?
Old Nov 13, 2006 | 04:26 AM
  #31
bwilson4web's Avatar
Engineering first
Default Re: Cost of Oil Change under Warranty?
Hi,
Originally Posted by Resist
It is not that hard to figure out what weight oil is used, afterall Toyota will do an oil analysis.
Funny you should mention oil analysis:
http://hiwaay.net/~bzwilson/prius/pri_toil.html
http://hiwaay.net/~bzwilson/prius/pri_T_cold.html
I've been sending transaxle oil samples for analysis and it looks live the viscosity, the primary oil characteristic, changes pretty dang quickly. Some of the additive levels can help but ordinary oil tests don't do a very good job of oil identification.
The reason I bring this up is good engineering is based upon a combination of physics, chemistry, math and measurements. There is nothing wrong with making a reasonable change when it is supported by testing. So when I switch to 0W-20, I'll also have not only the virgin oil tested but I'll also have a plan to take intermediate samples and test them. If there is evidence of a problem, I'll switch back and test. This is how engineering works.
Now I know folks who only 'follow the book' and I wish them well. I am amused that if you cross a border, Canada, Alaska or Japan, you'll find a new set of memos. But fortunately, that works too.
Bob Wilson
haroldo
Jun 30, 2009 06:27 PM
ndabunka
Toyota Highlander Hybrid
Jan 17, 2008 09:20 PM
DougD
Jun 3, 2007 10:17 AM
jimmy1
May 19, 2007 02:57 PM
blueskies
Sep 12, 2005 04:00 PM
