o2 Prius gas tank belch almost got me today!
Old Nov 13, 2006 | 01:32 PM
TonyK's Avatar
Default o2 Prius gas tank belch almost got me today!
Almost got a gas bath today by filling my Prius slowly beyond the 2nd click of the pump. I heard about these tank vomits BUT now know them all too well. I saw the fuel all of a sudden rise in the filler neck and shut the pump off asap. I eased the nozzle out and man did the gurgling from hell start! If you fine folks hadnt mentioned this in the past I would have stood there like an idiot. The fuel bubbled and then was sucked into the tank real quick.
Can you tell this is the 2nd time I filled this car with fuel? The first time was uneventful.
It was a tad strange (sad) today when I calculated the mpg since last fill up that was up to the top last time. Maybe there are different levels of full, I know I have heard about these funky tanks.
The display said I was averaging 54.3 mpg for the last 275 miles BUT it took 7.1 gals of fuel which brings the actual mpg down to some 38ish. The gauge was 2 ticks above half tank mark.
Is the bladder tank really 'that' erratic to calculate mpg's with?
thanks
Tony
Old Nov 13, 2006 | 02:00 PM
bwilson4web's Avatar
Engineering first
Wink Re: o2 Prius gas tank belch almost got me today!
Yes and no. Yes, it is unreliable for individual fill-ups. But over the long haul, multiple tanks, it is the gold standard. Click on my signature block and you'll see what I mean.
What I recommend is use the pump numbers for long term consumption and the MFD for 'tests' and 'experiments.' Personally, I still harbor some doubts about the accuracy of the MFD and some of the fleet reports support this:
http://avt.inl.gov/pdf/hev/sae_hev_p...ation_2006.pdf
See pp. 33 of 36 "End-of-Life Phase II (J1634) Vs. Onboard Vehicle Computer MPG" chart:
Civic 1 AC off +21.7%
Civic 1 AC on +21.0%
Insight 1 AC off +11.0%
Insight 1 AC on +11.7%
Gen I Prius AC off +15.7%
Gen I Prius AC on +14.7%
The vehicle computers are reporting the higher MPG values. This is consistent with my observations, the MFD mileage is consistently optimistic.
Bob Wilson
toast64
Off Topic
May 6, 2008 11:03 PM
08hybridok
Nov 14, 2007 08:00 AM
ShellyD
Mar 30, 2007 04:51 PM
Khabita
Mar 10, 2007 10:47 PM
clayk
Oct 16, 2005 07:15 PM
