Trailer wiring on 2006 HiHy
Old Mar 31, 2006 | 04:06 PM
jczibba's Avatar
Default Re: Trailer wiring on 2006 HiHy
the 10 amp fuse included with the wiring harness from Draw Tite is the wrong size and the manual says it should be 20 amps - which amp rating did you use?
Old Apr 14, 2006 | 09:01 PM
dlongor's Avatar
A 10 amp will work, if you have a 5X 8 trailer. I installed a 15 amp.
Old Jun 28, 2007 | 02:07 PM
Ingenuitor's Avatar
I recently installed a trailer hitch (all parts from etrailer) on my 2007 HiHy. The advice was much appreciated. Getting to and from the buried wiring connection was indeed the hardest part. It didn't help when I dropped one of the snap clips down the well just as I was finishing up. Now I just need to find out where to install the fuse supplied in the Tow Ready trailer wiring kit.
Old Jul 11, 2007 | 06:17 AM
Robb100's Avatar
Default Pics
Can those of you with hitches post pics of them? I would like to see what the different models look like (drawtite, hiddenhitch, toyota, etc.)
thanks
Old Jul 11, 2007 | 08:11 PM
Don R's Avatar
I believe that the Toyota hitch is one of the best looking hitches as it has a nice bend symmetry around the tailpipe that is also reflected on the other side. Aftermarket hitches often just slap in an ugly U bracket around the tail pipe.
The Toyota hitch also has a built in wiring harness that includes the trailer connector mounted nicely to a welded bracket.
Lastly, I am hopefully that Toyota's hitch will not flake off all its paint in a few years making the back of the Highlander look awful. I have much experience with aftermarket hitches and they typically turn to rust rather quickly. As the Highlander hitch is fully visible by necessity due to the spare tire, its appearance may be an important consideration.
Old Jul 12, 2007 | 05:11 AM
Robb100's Avatar
Thanks. That's exactly what I wanted to see. BTW, where is the plug located? I don't see it in the picture.
Thanks again,
rob
Old Jul 12, 2007 | 07:35 PM
Don R's Avatar
econoline
Nov 21, 2013 05:18 PM
us035976
Oct 15, 2012 03:03 PM
PHANTOMMADMAN
Jul 27, 2007 06:19 AM
prstone50
May 11, 2007 07:37 PM
HoslerD
Oct 14, 2006 04:37 AM
