"B" letter on shifter
Old Nov 26, 2008 | 03:45 PM
jbollt's Avatar
Default Re: "B" letter on shifter
Originally Posted by JHSmith
As Stanley wrote, the one big difference between the Prius and TCH's CC is that the TCH retains preset speed after slowing below 25 mph (even if you stop). Naturally, if DOES get erased if you turn the car off.
My Japan built 2007 TCH looses it's preset CC speed when slowing below 25mph.
edit: Perhaps this is a subject for a new thread?
Old Nov 27, 2008 | 12:36 AM
rburt07's Avatar
I was surprised to see the TCH cruise engage at 25/26 mph. Most cars that would be a high gas consumption setting to the the low rpm of the engine. Not so with the TCH as the Atkins Cycle engine is designed to be efficient at low rpm. Many times at 25 mph with the Cruise on I can go a ways in the EV mode if the street or road is level enough. My '07 TCH won't engage the Cruise if i'm under 25 mph.
Old Nov 27, 2008 | 08:05 AM
mfsandli's Avatar
I have a large decent near my home and have experimented with this(engine braking) several times. If i only use the brake pedal, I never get a full SOC, but when I combine the B with the brake pedal, it is the only time I can get the last bar to read full on my battery.
Old Nov 27, 2008 | 08:22 AM
wwest's Avatar
Originally Posted by SPL
I believe that, if the NiMH battery isn't "full," regenerative braking is actually increased when in 'B,' compared with 'D.' Certainly, the power flow arrow still points from the wheel to the battery in the MFD. In addition to increased regenerative braking, the ICE is also spun up to provide (lossy) engine braking. The total amount of braking is thus substantially greater in 'B' than the mild amount of regenerative braking applied when coasting in 'D.'
My TCH's CC retains its memory even when the car is braked to a stop.
Stan
I suspect that even in "B" mode that engine compression braking is NOT used unless you are actually BRAKING, the frictional brakes are in use. It would make no sense to "save the brakes", prevent then from overheating, if they are not being used.
And I see no reason that regenerative braking would be completely discontinued (absent a FULL SOC) in any case, just forcing the engine to turn over with throttle fully closed as an aid to frictional braking.
Old Nov 27, 2008 | 10:42 AM
SPL's Avatar
SPL
jbollt — My previous (1993) Camry did lose its CC memory when the car was braked to a stop (or even to below some minimum speed, but I forget what it was). The TCH is different, and I'm sure you'll find that, if you manually accelerate to >40 km/h (~>25 mph), the "resume" will work, showing that the previous CC setting was still in memory. My TCH is a Japanese-built 2007 model, but I'm sure that they all behave similarly.
wwest — Engine braking is definitely used in the TCH in 'B' mode. Scangauge shows this clearly if you shift to 'B' while coasting in EV mode in 'D' at say 50 km/h (~30 mph). The ICE rpm goes from 0 to >1000 rpm, while staying open-loop. Coasting at higher speeds, the ICE rpm can go much higher (to 3000 rpm or above), so applying even more engine braking. The arrow in the MFD, pointing from the wheel to the battery, indicates that regenerative braking is also being applied, provided that the battery isn't "full." Applying the brake pedal in addition presumably increases the regerative component, and will also bring in the friction brakes if enough force is applied (or the battery becomes "full"). The reason for spinning the ICE like this in "fuel-cut" at speeds above ~64 km/h (~40 mph) has been discussed before in other threads (search on "fuel-cut"), and is related to the safe operation of MG1, whose speed would become excessively high (or pose an electrical over-voltage risk to the motor-drive electronics) at these road speeds were the ICE left stationary.
Stan
Mainiax
Aug 19, 2010 09:14 PM
mikieboyblue
Aug 30, 2007 12:06 PM
spiff72
Nov 7, 2006 09:17 AM
MacBrando
Apr 7, 2006 09:06 AM
peggy
Sep 16, 2005 07:13 AM
