Gear shifter problem
Old Sep 13, 2005 | 04:08 AM
peggy's Avatar
Default Gear shifter problem
I've noticed and it's gotten progressively worse an issue where the gear shifter seems to slip out of position enough that the car won't start. I have to hold the shift all the way forward and start the car with my left hand. It's like the car thinks it's not in park. Don't happen all the time but seems more prevalent in the morning. It doesn't happen as much in the afternoon or evening. Anyone else have this problem and what did the dealer do to repair it? I'm having it looked at Friday when I go in for my 20,000 mile checkup and recall work.
Old Sep 13, 2005 | 04:30 AM
Wangofree's Avatar
Default Re: Gear shifter problem
Hi Peggy,
I'm no expert, but it sounds like the "neutral safety switch" might not be set right. I'm not suggesting you try this, but if it was me, I would pull out the tab or "little door" next to the gear shift. This is the shift release. I would push my key into and move the shifter back and forth. It is designed to allow you to "unlock" your shifter when it becomes stuck.
This may realign it, or it may not help at all.
Old Sep 16, 2005 | 07:13 AM
peggy's Avatar
Originally Posted by Wangofree
Hi Peggy,
The problem turned out to be the trans range selector switch.. whatever that is.. it was having intermittent failures.... the dealer had to order the part because he said he's never seen one go out... maybe but i had the same problem with the cr-v but never worried about it because it wasn't as bad..
Geckoboy
Jul 13, 2013 08:52 AM
jg013c
Nov 9, 2008 05:39 AM
Sky Blue
Aug 15, 2008 12:36 AM
mikieboyblue
Aug 30, 2007 12:06 PM
MacBrando
Apr 7, 2006 09:06 AM
