Anyone using a Treo 700p with their TCH?
Old Oct 24, 2006 | 05:35 PM
schmidtj's Avatar
Keeping Toyota Solvent
Default Re: Anyone using a Treo 700p with their TCH?
This is how I transfer the entire phonebook (Category ALL) or a specific contact category from my Palm based Treo.
From the TCH:
Info->Telephone->Settings->PhoneBook->Transfer Data->Group ## or No Group
From the PALM based Treo:
Applications->Contacts->Select Category->Menu->Send Category->Bluetooth->OK->Nearby Devices->OK->Select Camry (HANDSFREE)->Done
Old Oct 24, 2006 | 07:56 PM
Big-Foot's Avatar
Currency-to-hydrocarbons
From the TCH:
So I take it that I have to do the functions on both the TCH and the Treo in order to make the transfer - correct?
Thanks for your help on this!
Old Oct 25, 2006 | 04:13 AM
schmidtj's Avatar
That is correct. Also I should mention I have the NAV version of the TCH. Not sure what the TCH end of things procedure is for the Non-NAV TCHs but the Treo-side procedure would be unchanged for the Non-NAV.
Basically you need to put the car into "I am ready to receive" mode and the phone set to "Here it comes" mode.
Old Oct 25, 2006 | 07:58 PM
Big-Foot's Avatar
Got it - worked like a charm! Thank you!
Old Apr 24, 2007 | 06:12 PM
CkGoGreen's Avatar
Talking Re: Anyone using a Treo 700p with their TCH?
can i just say, i love my new 2007 prius. picked it up last Friday, have 37 miles on it. it's fabulous! i'm reading like crazy and running down to the car every five minutes. this is my first post as an 'anything' enthusiast.
the bluetooth on my treo 650 synced immediately and has worked like a charm. no sound problems as BIG-FOOT mentioned. my friend says it sounds great.
like LILARIENNE, i haven't been able to get contacts transfered either. my treo does not need an update at this time. i checked and it's already at 1.17. i appreciate the reminder from SCHMIDTJ.
i was going to next try SCHMIDTJ's solution. so happy to catch that. however, i did something to knock the signal off and can't get it back on. so i'll try again tomorrow.
what did i do? i hit the power button and you know how quiet this car is! how sometimes it'll idle and then just gear up. well it geared & sputtered! HUH? so i hit the power button, (one for off, one for on) and as an experiment i put my foot on the accelerator. it scared me silly...and wouldn't stop!! so i hit the power button again (2xsame). and THAT's when i noticed the bluetooth didn't connect and NOW it won't find the darn thing. i had all kinds of things on the dash flashing at me.
i hope i didn't ruin my break-in period with that little stunt.
p.s. can you guys tell me what TCH means? i'm seeing that a LOT!!!
Old Apr 24, 2007 | 06:34 PM
schmidtj's Avatar
Old Apr 24, 2007 | 08:11 PM
kris's Avatar
Totally Cool Hybrid, ~dude~
Old Apr 25, 2007 | 05:54 PM
Big-Foot's Avatar
I had one episode where the BT in the TCH would not connect with the Treo 700P. I went through all the menus in the NAV and could not figure it out. Finally realized I was fiddling with the wrong component in the puzzle. Did a Reset on the Treo and all has been fine since..
Old Apr 26, 2007 | 11:33 AM
CkGoGreen's Avatar
i soft set, hard set and then realized "I" was fiddling with the wrong component, went to the NAV and started AT THE BEGINNING with the 'register' button and all was well with the BT connection.
still can't get my data transfered. treo 650 to 2007 prius. thanks for your help. Ck
vin888
May 11, 2008 10:36 PM
CkGoGreen
Feb 3, 2008 02:54 PM
haroldo
Nov 24, 2007 01:59 PM
schmidtj
Jun 7, 2007 06:07 AM
Advance The Man
Website Questions & Input
Sep 18, 2005 04:53 PM
