Question About FAS
Old Sep 22, 2005 | 07:18 AM
VampHuntD's Avatar
Default Re: Question About FAS
Xcel,
Thanks very much for your reply. I've only done a FAS once and that was at 3am when I was alone on a rather large road. I have no plans to use it when anyone else is around me (I learned all about it beforehand, just hadn't done it). Thanks again!
Old Sep 22, 2005 | 09:16 AM
zimbop's Avatar
Originally Posted by geologyrox
i'm also curious to know if anyone knows if just dropping into neutral, and not turning it off and on again, would result in good gas milage? I am getting very used to just slipping the car intoo neutral, and (just out of a silly heebiejeebie type thing, i guess) would rather put it into neutral than turn it off. Thanks =)
I regularly shift into neutral to coast without turning off the car. My real time mpg display skyrockets and I watch the trip mpg indicator increment up the more I coast. It does save gas. Perhaps not as much as turning off the engine, but I don't like the idea of that so I don't do it. I coast on long downhills in neutral with the car on and it does increase my FE noticeably.
One thing I do to reduce wear on the cvt is to rev the engine up to the expected rpm's before switching back into drive, sort of like double-clutching, so the engine is more closely matched to the required rpm's before I engage the cvt. I don't really know how much difference this makes but it is a smoother transition and so I assume its making less wear on the cvt.
Those of you who do the FAS by turning off the car, do you restart it with the key, or do you roll-start the engine? What about in a cvt?
Old Sep 22, 2005 | 10:14 AM
gonavy's Avatar
https://www.greenhybrid.com/discuss/...ders.3640.html
This was a thread about N-coasting in the Accord (we are unable to FAS under most conditions due to our transmission configuration). Definitely much better than staying in gear. I don't know of anyone on any platform who has put together anything similar to find the delta between N and FAS.
Any volunteers?
Eskrimast1
Apr 6, 2006 02:14 AM
martyllian
Mar 20, 2006 06:20 PM
xcel
Mar 20, 2006 02:36 AM
infinkc
Sep 10, 2005 12:19 PM
weyus
Sep 2, 2005 04:38 AM
