Question About FAS
Old Sep 19, 2005 | 10:02 AM
VampHuntD's Avatar
Default Question About FAS
Can someone in detail explain a FAS? I tried to do one this weekend and I didn't really see an improvement. What I did was shift to neutral turn off the car, then turned it back to position 2 and coasted while still in neutral. Was that right? As a side note, it's really weird when the sudden silence hits you when the car goes off!
Old Sep 19, 2005 | 10:08 AM
psyshack's Avatar
Default Re: Question About FAS
Thats what you do. Switch engine off and leave ingnition on like car was running and coast. It helps our standard Accord alot. Hard to make up the wifes awful fe but helps. I have some .5, 1 and 1.5 mile FAS. Its great!! And coasting up hill ROCKS!!!
Old Sep 19, 2005 | 10:11 AM
VampHuntD's Avatar
So I switch back to position 3 instead of 2 after turning back on? Isn't that harmful to the car?
Old Sep 19, 2005 | 01:41 PM
livvie's Avatar
huh? if you go back to 3... the car starts.
Old Sep 20, 2005 | 08:14 AM
VampHuntD's Avatar
Sorry I was confusing it with another car where 3 was the point before ignition, rather than the ignition point. So then it's position 2 that I coast in.
Old Sep 20, 2005 | 09:11 AM
xcel's Avatar
Hi VampHuntD:
___It sounds like you got it. Just make sure you boot up the electronics so the speedo/odometer are live but the ICE is off is all.
___Please be very careful and practice/learn the technique on a desolate road or at times when traffic is at an absolute minimum. It is not second nature to you yet and it is very important that it becomes so before you begin to use it on a whim whenever and wherever on your day to day commute.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old Sep 20, 2005 | 02:56 PM
geologyrox's Avatar
i recently read a post mentioning 'neutral dropping' as a possible cause of early retirement of a car. I did a search, and found that many people thinkcoasting in neutral is downright dangerous - something I don't agree with, because I do it all the time, and have just as much control over my car. I could not really tell, however, if that was the 'neutral dropping' that was supposed to cause engine damage. could i talk someone who knows about this into shedding some light on the subject?
i guess what i'm asking is if doing this FAS thing is bad for the car. i'm also curious to know if anyone knows if just dropping into neutral, and not turning it off and on again, would result in good gas milage? I am getting very used to just slipping the car intoo neutral, and (just out of a silly heebiejeebie type thing, i guess) would rather put it into neutral than turn it off. Thanks =)
Old Sep 20, 2005 | 03:10 PM
lakedude's Avatar
Dear geologyrox
Riding the clutch does cause wear on the throwout bearing and will cause problems in the long run. You don't want to coast with the clutch pushed in. Shifting the car into neutral should not cause any damage, all you are doing is disconnecting the engine from the wheels. You do this every time you come to a stop anyway so no damage should be done to your car from coasting in neutral AFAIK.
Note: This info is for a manual only. I've heard it is not a good idea to coast in N with a normal automatic.
Old Sep 20, 2005 | 03:25 PM
lakedude's Avatar
Here is what Tom and Ray say about it:
Dear Tom and Ray:
I really enjoy your column, and have learned a lot over many years reading it. I have a 1992 Toyota Tercel with a standard transmission. I am on social security, so I'm trying to save every penny I can. I spend most of the year in rural Georgia, with a lot of hills. So at first, I was coasting down the hills in Neutral with the engine on, thinking that might save some money over the years. Now, I am turning off the engine, and then putting the car in the appropriate gear to restart it later on. I can travel two to three miles several times going to town this way. Am I ruining any mechanical parts by doing this? And is it worth the little bit I'm saving?[bluecar.gif] Roberto
Tom: Gee. You really are a world-class cheapskate, aren't you, Roberto? A man after my own heart.
Ray: Here's my calculation: This car gets about 40 miles to the gallon. So if you coast two miles with the engine off, you're saving 2/40ths of a gallon, or about a nickle.
Tom: But when the engine is off, you're in danger because you don't have any power brakes. Plus, one of these days when you shut off the engine, you're going to turn the key too far and get it into the "lock" position and lock the steering wheel.
Ray: Then you're going to plow into one of those roadside-boiled-peanut vendors, and he's going to sue you for five million dollars, which will more than wipe out the three bucks you saved by coasting.
Tom: Besides, I'm sure what you're doing is illegal. In fact, it's even illegal in most states to roll down a hill in Neutral with the engine ON! Even with the engine on, the car could stall, and you could lose your power brakes and power steering and never know it until you needed to stop or turn.
Ray: So I'd stay in fifth gear and look for a safer way to save a few pennies. You can start by writing shorter letters, Roberto. Then you can use postcards, and save 10 cents on every stamp.
Old Sep 20, 2005 | 05:48 PM
bigbearballs's Avatar
So, it's not going to hurt our HCH's to P&G.
