Calculated Mileage differers from Actual?
Old May 23, 2006 | 10:10 AM
Anahymbrid's Avatar
Default Re: Calculated Mileage differers from Actual?
I had my 4th fill up this morning. Again, I took it to the filler neck. This time it was only 1.4 mpg off (dash gauge reading low). The last two tanks were exactly 2.0 off.
Old May 23, 2006 | 10:22 AM
Mr. Kite's Avatar
Originally Posted by dburanich
I started to check my calculated mileage vs the display and discovered it would almost never match sometimes over and sometimes under. This led me to believe that I am never filling up in the exact same manner. There are too many variables involved, incline at the pump, pumps varying, the only sure way would be to park at the exact same pump in the exact same spot and fill up until you can see the gas at the top of the filler. If you put 500 miles and your fill up can vary by only a half gallon (which is quite easy to do) it can affect your mpg reading by 2 mpg or more. I have since quit comparing and rely on the display.
From my limited experience and from the posts here, it seems that the HCHII display FE is consistently low (~2mpg). If you want accurate numbers, you have to calculate the FE yourself. It is true that you could have some variation from tank to tank, but this is the best way to monitor lifetime FE. If the display is off by a few mpg, there is no other way around it. I know this is really trivial and a few mpg may not be important to you.
So far, I have been calculating and recording the display number when I refuel.
Old May 23, 2006 | 12:32 PM
EZ2beGreen's Avatar
Every non Honda I have experienced is always 5-10% higher on the trip computer reading as opposed to the acutual figure measured at the pump.
The only Honda I have owned with a MPG computer (2006 Odyssey) is consistently within 1MPG, and consistently displays a slightly lower number than acutal pump measured FE.
I have yet to check out the HCH, as I have not even filled it up as yet!
Old Aug 4, 2006 | 06:31 AM
XerEagle's Avatar
My FE is off by approximately 2mpg when comparing the HCH II’s display compared to calculating the FE. The HCH II display is lower – to help try and eliminate possible differences in calculating (filling up to the same level each time), I used the same gas pump, filling at the same flow rate and the difference is around +2mpg in favor of calculating the numbers.
Old Aug 4, 2006 | 09:31 PM
Cryx's Avatar
Same here, my computed mpg is usually +2 over the display.
Old Aug 4, 2006 | 09:51 PM
Mr. Kite's Avatar
My lifetime average is now at 55.18 mpg. Using the dash numbers to calculate gas usage per tank and then calculating lifetime average, it is 54.25 mpg. This is a difference of 0.93 mpg (1.69%) through 4,479 miles and 81.17 gallons.
Old Aug 5, 2006 | 07:03 AM
  #27
cocoapunk's Avatar
Hi,
I have a HCH II (2006) and I'm actually getting 5.7 mpg over what the reading says (I calculate 40.1mpg but the display say 34.4mpg)
Does anyone else notice this much of a deviation?
Old Aug 5, 2006 | 09:31 AM
  #28
FourSticks's Avatar
On 3 tanks of gas so far. My calcualted is 2% over the display listing.
Mike
ButchVA
Jun 17, 2007 12:56 PM
JoeFuture
Jan 29, 2007 04:34 PM
SafetyGuy
Apr 12, 2006 01:18 PM
CamelFilters
Mar 5, 2006 09:29 AM
zimbop
Aug 15, 2005 03:16 PM
