Has anything broken on your HCH II?
Old Aug 20, 2006 | 10:11 PM
  #81
Flash's Avatar
Default Re: Has anything broken on your HCH II?
(Psssst, Anahymbrid, keep the post on-topic <grin>) I'm actually more interested in looking for the door that has now been removed but I'll keep searching.
As for the update instructions -- I plead the 5th. I mentioned something about that to a friend of mine who owns an '01 MDX and he wanted to drive my car to see what it was like. When he returned it wasn't until several hours later when I left his place - and I noticed the startup screen was modified. I didn't do it since it voids the warranty as noted in the DVD manual but if you email me then I can get the steps from my friend and let you know what he did.
Old Aug 21, 2006 | 11:46 AM
  #82
Anahymbrid's Avatar
oops. Sorry! Just saw that someone had successfully changed the display and couldn't contain myself!
As for the door, I noticed that mine was flimsy, but I have yet to remove the DVD, so I haven't broken it yet!
Old Aug 21, 2006 | 01:27 PM
  #83
Flash's Avatar
No biggie (re: on-topic). As for the door though be sure to flip the DVD door shut after you put the DVD in otherwise the Nav screen will try to close on it and gears will grind incorrectly. I only removed the DVD because the original setup was not meshing with my location, etc. but removing the DVD then inserting it fixed that problem.
Old Aug 21, 2006 | 08:35 PM
  #84
gumby's Avatar
Energy Independence
I'd try looking for a stereo repair shop, and ask them if they can match this part (DVD door) to an Alpine part, since this IS an Alpine unit. Maybe even contact Alpine themselves.
I know Marantz and Pioneer used to be good at letting anyone order replacement parts from them.
Old Aug 21, 2006 | 11:05 PM
  #85
helicraz's Avatar
Originally Posted by helicraz
I got the window problem too.. started yesterday, but it didn't happen today.
I didn't do anything to mine.. and it seem to have gone away by itself... it has been working fine for 4 days so far.
Old Sep 23, 2006 | 06:02 PM
  #86
Artoodetoo's Avatar
I had to take mine in for repair because the driver side window was not rolling up properly. Honda had to replace the rubber seal that guides the window. Had my car back the same day.
-Ronald
Old Sep 28, 2006 | 11:09 PM
  #87
Rick's Avatar
Two dumb things I'm taking my car in for on tuesday. One is my passenger side sun visor is trying to push itself apart. The spring mechanism that keeps it in the up position is pushing the two plastic pieces apart, and they have this issue so often the dealership stocks sun visors for 06 Civics, but of course they didn't have the one for the Hybrid.
The other problem is my glove box is squeeking incessantly. It's developed a plastic against plastic squeek that's been driving me crazy. They're going to look at this, hopefully they won't have to order parts and I have to bring it back again.
Old Oct 1, 2006 | 01:30 PM
  #88
3PuttPar's Avatar
Originally Posted by derek
Looks as if the 06 Civics may have a design flaw -- my Civic started having the window problem too (4000 mi). I noticed a couple weeks ago that when shutting the driver's door window with the "auto-up" button, the window would get almost all the way to the top and the suddenly reverse and go back down. But yesterday I noticed that the rubber track was pinched which was causing the window to jump out of the track. I was able to bend the rubber enough to get the window back in place. I am hoping that some silicon lube will keep in there.
Derek, I read your post on greenbybrid.com r.e. your driver's side window not closing properly with the "auto up" feature. I have an '06 HCH with Nvi and started seeing the same behavior at about 1,000 miles. Did the fix you mentioned in the post work OK? Thanks, Robb
Old Oct 2, 2006 | 07:53 PM
  #89
derek's Avatar
The silicon lube fixed the problem for me. A can of the lube cost $1.82 at Walmart. I apply the lube whenever I wash the car. Make sure it is definitely "silicon" which is for rubber and plastic. You wouldn't want to use a petroleum-based lube which could destroy the rubber seal.
I have read from others that Honda is aware of the problem and has a fix for it too -- so you could go to the dealer if you don't want to deal with it.
Old Oct 7, 2006 | 09:28 AM
  #90
50Plus's Avatar
15,000 miles, 11 months of ownership. One rattle in driver side by seat belt fixed at 9,000 oil change; few other minor rattles now all gone.
MPG keeps improving......now at an average over the 15,000 miles of 51 mpg.... probably 50/50 freeway/city driving.
Having owned Hondas for years (Civic sedans and hatchbacks, CR-Vs, one Accord), the HCHII is the best of them all.
Just a wonderful car...................
