2008 hybrid Tahoe: stalling out, check engine light
Old Feb 10, 2020 | 05:58 PM
  #31
Chicago38's Avatar
Default Re: 2008 hybrid Tahoe: stalling out, check engine light
Originally Posted by Don “Alphabet” Wrnis
Was the Hoffman tire pro the shop that did your hydraulic clutch diagnosis? I have 235k on mine and starting to have some issues with the hybrid and I believe it may be the clutch as well. Need a reputable hybrid shop anywhere between Destin Fl and Charlotte NC. Anywhere along 65n to Montgomery AL then 85N from Montgomery to Charlotte NC. Atlanta is my halfway point so S. Of Atlanta would be perfect.
I'm from Destin Fl I have Chevy Tahoe hybrid it's have transmission problem but I can't found some body who can help me to :-(
Old Feb 13, 2020 | 11:50 AM
  #32
Tahoe_08's Avatar
how old is the 12v battery? this thing is electrical even the Accessory power module(inverter) can't supply the necessary power for the SUV even though some might claim it will i would also check the battery cables they tend to come loose overtime esp on the older models i.e 08-09 you will have to resit them on the battery
Old Mar 18, 2021 | 07:28 PM
  #33
Willy Campoverde's Avatar
Originally Posted by chrisylis
Hi
I had this problem and it was driving me crazy. Finally I managed to find an answer for the whole stall out problem. My 08 Yukon has only a D and M on the shift lever. If I put it in M it automatically overrides the auto stop. I love this car but I was going to sell it until I found this fix. It defaults to M4 on the display. So gears 1 through 4 shift normally. I just put it back in D on the freeway. Problem solved!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hi I dont understand how you solved the problem. mine has the same prob. drives so smooth but will die when I STOP at a light.. how do I prevent that. was told to chance the battery
Last edited by Willy Campoverde; Mar 18, 2021 at 07:29 PM. Reason: too manual typos
Old Mar 19, 2021 | 02:38 PM
  #34
Tahoe_08's Avatar
are you sure that is not "auto stop"?
Thomas C. Morton
67
Feb 3, 2021 04:33 PM
ilovelucy
Nov 4, 2015 08:29 PM
Derekc
13
Apr 12, 2014 09:15 AM
BIG DAVE
May 1, 2013 03:13 PM
