tpms
Old Dec 10, 2006 | 06:53 PM
TeeSter's Avatar
Default Re: tpms
Originally Posted by andyh
Good question. Although there would still be just 4 sensors near the car (or 5 if there's one in the spare, which I don't actually know), I'm assuming if they're the right ones, it's just going to work. But I don't know that. Could they need "activating" or "synching" to the car system?
The manual is a tad limiting.
You'd think the system has to be programmed... otherwise if you are next to another escape on the freeway or road... how would it know which 4 tires to listen to?
Old Dec 11, 2006 | 04:15 AM
WaltPA's Avatar
Default Re: tpms
If your Escape's tires are only a couple of inches away from another Escape's tires, while on a freeway or road, I think tire pressure is the least of your worries.
Old Dec 11, 2006 | 06:02 AM
TeeSter's Avatar
Default Re: tpms
More like several feet..... the receiver is going to be in the front of the vehicle... and it has to pick up the reponse from the sensor in the back. Likely its similiar to an RFID tag, and you'd have to allow for some margin of error.... I think picking up the car behind you or next to you in a parking lot is quite likely and would have to be accounted for.
Old Dec 11, 2006 | 06:16 AM
WaltPA's Avatar
Default Re: tpms
I thought the receivers were quite close to each wheel, like near the ABS sensors?
Old Dec 11, 2006 | 07:25 AM
TeeSter's Avatar
Default Re: tpms
I went online to a few manufacturers of TPMS sensors... Some of them also sell handheld units for "programming" them to be recognized at the factory. The company I looked at does sell to Ford (I'm forgetting its name now).
In any case, at least in SOME of the systems it appears the sensors (or the receiver) have to be programmed to communicate properly.
Old Dec 11, 2006 | 06:35 PM
andyh's Avatar
Default Re: tpms
The transmitter only sends out a bleep every so often, and I think there's a good chance the light doesn't go on the very first time it gets a strange blip....sounds like it might want to get several sequental signals for low pressure before it turns on. It wouldn't be hard to have generic transmitters, but disregard things if you're getting funny signals, and wait a few minutes until things are clear. The whole system is pretty hokey by the description, and not all that accurate.
Old Dec 12, 2006 | 04:14 AM
WaltPA's Avatar
Default Re: tpms
.... but being and engineer, ...
I art and engineer two.
Old Dec 12, 2006 | 05:32 AM
TeeSter's Avatar
Default Re: tpms
Opps I edited my message instead of posting a new one....
Old Dec 17, 2006 | 03:12 PM
pquig's Avatar
Default Re: tpms
The sensors have to be "trained" which is outlined in the service manual. I had it done when I had a TPMS module installed in my full-sized spare. The ignition switch must be cycled from OFF to RUN three times, then left in RUN; the brake pedal is pressed and released; the ignition is then switched between OFF and RUN another three times, leaving it in the RUN position, at which time the message center should say "TRAIN LEFT FRONT TIRE". The activator is placed near the LF sensor (opposite the valve stem) and the horn will beep when the sensor is trained. You then proceed to the right front tire and follow sequentially clockwise to train the sensors. It won't work if you do them out of sequence.
Wheel rotation does not affect the training (according to the information I've been given and past experience).
Old Dec 19, 2006 | 09:03 AM
ag4ever's Avatar
Dazed and Confused
Default Re: tpms
Originally Posted by nitramjr
My father's Buick Century has the TPMS in it and it is a POS (the TPMS, not the car). Unreliable to the point of being ignored when it does come on. Then it has to be reset after airing the tire.
On my parents Buick Centurys, the systems measures wheel rotations, and if on wheel starts to rotate more times than the others it triggers the low pressure alarm. I assume the FEH system will use sensors like the TCH systems does, and if that is the case, I would assume it to be much better. The only problem I see is the pressure it allerts you to. I have my tires pumped up to 40-45 PSI, while Toyota recomends 30ish. So by the time the sensor tells me the tire is low, I am way lower than what I want it to be. I think there should be a way to set the sensors at a desired pressur level, and have them alert you if you fall below that level.
EOppie
Apr 8, 2007 06:04 PM
andyh
Jan 16, 2007 11:53 AM
WVGasGuy
Jun 8, 2006 04:52 AM
