How Far does your emergency brake go up? And any Service Idea requests.
Old Mar 23, 2007 | 11:55 AM
Jerry&Natalie's Avatar
Default Re: How Far does your emergency brake go up? And any Service Idea requests.
After the bumper to bumper warranty runs out, I do all of my own service, except oil changes, which is cheaper at the shop and they can recycle the old oil. find/ steal/ borrow a FSM and you will be free of most shop labor.
Case in point. A friend sent me a FSM for my dakota. In the past 4 months alone I have fixed a caliper issue (TSP), installed pads, rotors and adjusted rear drum brakes, changed a timing chain/belt, all new belts & hoses, installed new shocks, replaced all the door rubber, replaced a cracked window and installed a new exhaust system including the cats. I saved at least $1000.00 labor with a few handtools and free time.
Not sure about the FEH E brake set up, but most are mechanical (cable) setups using a drum on the rear hubs. raise the parking brake handle and there is an adjustment screw. Turn it out ( counter clockwise to loosen, clockwise to tighten.
Your squeak is metal on metal. make sure the gasket on top of spring perch is still there or it may be a spring coil touching another spring coil. I use silicone to silence this. Another thing to look at is the rear shock mounting bolt. lube is with silicone and make sure torqued to spec.
Let us know!
Defender
190
Feb 18, 2021 06:05 PM
EOppie
Apr 23, 2019 06:21 AM
noflash
Apr 22, 2008 09:13 AM
bunny
Feb 29, 2008 12:38 PM
tourretired
Aug 19, 2005 09:28 AM
