2009 Ford Escape Hybrid Driver Climate Control Not Working
Old Feb 8, 2019 | 04:41 PM
phill122004's Avatar
Default 2009 Ford Escape Hybrid Driver Climate Control Not Working
Hey Guys,
I have been working on trying to figure out why the driver side climate control **** is not working. I can turn it right or left but the temperature is stuck on 75. Pressing the Auto button in turns on the AC/HEAT but I am unable to adjust the temperature. The passenger side **** works just fine. I ran the Ford Self Diagnostics test on it and received these codes. 12 BO = Front Blower Motor Relay Drive Circuit Open or Shorted to Ground
12 BF = Heated Backlight/Mirror Relay Drive Circuit Open or Shorted to Ground
I do not believe the resistor for the blower motor relay is bad, because the fan works just fine on every setting. The only issue I am having is that I cannot adjust the internal temperature of the car. Please let me know if you have any thoughts or ideas on what would be causing this issue. I have checked the fuses as well, but I could have possibly overlooked something. I called Ford and they said they had never heard of this control going bad before. Please Help!!!
Phil
This is the control that is not working
Msdp
Dec 9, 2016 02:04 PM
ofman1956
May 22, 2011 11:43 PM
noflash
Feb 28, 2007 10:11 AM
Civic06
Oct 3, 2006 12:38 AM
BowDirk
Apr 3, 2006 09:13 AM
