Nitrogen Filled Tires
Old Aug 13, 2006 | 07:40 AM
Tireman9's Avatar
Default Re: Nitrogen Filled Tires
Originally Posted by Double-Trinity
...... This was most dramatic when I last went in for maintenance and my pressure was lowered, coastdown speeds dropped,.......
You didn't identify your normal "cold" inflation or what it was lowered to.
The correct inflation should be
1. Checked at least once a month
2. Checked when "cold" - not driven on for at least 2 hrs and not in direct sun
3. NEVER set below the manufacturers placard inflation
4. You can run + a few psi but NEVER above the Max on the sidewall of the tire
5. Use an accurate digital gauge that reads to the half pound.
6. If ambient temperature changes by more than 20 degrees be sure to re-check and adjust the infl.
Tire engineer w/ 37 years experience
roseng
Nov 27, 2008 04:09 AM
tekn0wledg
Dec 22, 2007 07:20 PM
ppgroup
Jun 14, 2006 08:23 PM
team_venture
22
Nov 13, 2005 08:50 AM
newgreenie
Oct 24, 2005 01:00 PM
