Nitrogen Filled Tires
Old Jan 19, 2006 | 06:14 AM
dsusskind's Avatar
Default Nitrogen Filled Tires
I have been having problems maintaining proper tire pressure due to the recent temperature changes. I stopped by my dealer yesterday to discuss this with my service tech and she recomended having my tires filled with Nitrogen. Apparently, I will never have to check my tire pressure or refill the tires unless I get a flat.
As we all know, tire pressure is key to increased gas milage and i wasn't too expensive so I had it done.
I will let you know if it works.
Here is the link: http://www.whynitrofill.com/index.htm
David
Old Jan 19, 2006 | 07:23 AM
livvie's Avatar
Default Re: Nitrogen Filled Tires
Well... true that nitrogen will help maintain even pressure but don't count on getting better mileage because of that... and you don't have to believe me either. Just try filling your tires to MAX psi vs recommended psi. You will not notice a difference or a significant difference. You will notice that braking and handling will improve with more psi.
It's been discussed here to death. So do a couple of searches to find out other people's thoughts.
Old Jan 19, 2006 | 07:26 AM
Sledge's Avatar
YA RLY.
Air is 78% nitrogen. The gas used at these nitrogen fill stations is about 90% nitrogen. Are those 12 percentage points really going to make that much of a difference in a non-ultra-high performance application (read: racing)?
Old Jan 19, 2006 | 09:27 AM
foo monkey's Avatar
Nitrogen is a scam. It's essential for professional race car drivers, going upwards of 200 MPH, with tire and brake temperatures over 1000 degrees. It's a complete waste of money for anyone else.
Old Jan 19, 2006 | 09:51 AM
Bob259's Avatar
Automania Enthusiast
David
We used nitrogen in our race car tires for years. Expansion is very critical in high performance/race cars where excessive expansion changes drive ratios and uneven expansion makes for 'unique' handling or a possible 'Kodak' moment.
IMHO I do not see any benefits for passenger type vehicles.
Old Jan 19, 2006 | 09:52 AM
2Hybrids's Avatar
100% Committed
and cost effectiveness is minimal - for normal passenger cars, there doesn't appear to be any advantages.
Old Jan 19, 2006 | 10:51 AM
livvie's Avatar
The only reason why to go nitrogen is to reduce the amount of moisture entering into your tire. The water in your tire is what causes the huge spikes in pressure depending on tire temp.
If you go put air in your tire at any service station, you will notice the moisture coming out if you simply test the hose prior to filling up your tire. Just release some air from the hose, you will see this.
If the air pumps have a filter to capture the water, this will reduce the amount of moisture entering your tire. Water in your tire is the real problem.
Old Jan 19, 2006 | 01:13 PM
tko4you's Avatar
Just chiming in from my experience with Nitrogen filled tires and no one has mentioned the Tread life advantage.
Nitrogen filled tires run cooler... combined with a small increase in FE you also will see a small increase in tread life.
Food for thought.
Cheers!
http://www.bridgestone.com.au/tyres/...e/nitrogen.asp
Old Aug 3, 2006 | 06:16 AM
Tireman9's Avatar
Sorry but your service Tech is dead wrong. The only thing you will get with N2 inflation is a slower leakdown of inflation and minor reduction in pressure variation due to temperature changes. YOU MUST STILL check your inflation at least once a month.
The entire myth that inflating tires with N2 will deliver improved mileage is based on the assumption that you do not check and adjust the inflation in your tires as you have been told to. The car doesn't know what gas is used to inflate your tires. All it knows is the rolling resistance which is a direct function of the properties of the individual tire and the deflection of that tire (within normal operating speeds). The deflection is a finction of the load and inflation. Inflating with 32 psi of N2 will give same result as inflating with 32 psi of air or 32 psi of CO2 etc.
Tire Design engineer w/37 years experience.
Old Aug 6, 2006 | 12:48 AM
Double-Trinity's Avatar
In both my old stock tires, and especially in my newer lower-profile tires I saw a dramatic difference in coast-down speeds on certain long, sustained downgrades. This was most dramatic when I last went in for maintenance and my pressure was lowered, coastdown speeds dropped, then later that afternoon, the coastdown speeds returned to normal when I refilled them. MPG difference is small but definitely observable. The handling/steering feel difference is much more prominent, and the main reason I prefer high pressure.
