Engine Heater - Improve short trip MPG?
Old Oct 27, 2005 | 05:45 AM
jdenenberg's Avatar
Engineering Professor
Default Engine Heater - Improve short trip MPG?
Just a thought, would a low-cost engine heater reduce the warm-up time and significantly improve short trip MPG in my Prius(especially in cold weather)? I did some research and found one (Proheat Products Model 154) for under $50. It is a 125 watt heating pad that you stick to the underside of the oil pan. It seems like it should help.
Old Oct 27, 2005 | 06:37 AM
Delta Flyer's Avatar
Banned
Default Re: Engine Heater - Improve short trip MPG?
I've given that some thought myself. Less trouble is a heated oil dipstick, but it won't work if any engine parts are plastic.
Old Oct 27, 2005 | 06:43 AM
jdenenberg's Avatar
The pad is a semi permanent solution. It doesn't require raising the "bonnet" to remove it before driving out. All you need to do is remember to unplug it, which at my age may be an issue.
Old Oct 27, 2005 | 06:55 AM
Banned
Some of the heaters use a lot more wattage, making a timer a good add-on.
Old Oct 27, 2005 | 07:44 AM
zadscmc's Avatar
Have hybrid, will travel.
I am installing a block heater into my HCH at the next oil change at 50k (which is when I would normally change my antifreeze anyway).
I just see the one day I let my wife drive the HCH an her dragging the electrical outlet, ripped away from the wall, from our barn ::sigh::. "Oh, I didn't know..."
Old Oct 27, 2005 | 07:47 AM
Civic Duty's Avatar
Brains of the Operation
Oh no... it's happening. Even in SC, I'm not immune. Had my first few experiences with decreased mpg as the temps have been inthe 40s in the mornings lately. MPGs were in the 40s, too! At least it'll never be quite as bad as you subzero folks in the North.
Don't block heaters come standard on Canadian cars? Any Cdn Prius or HCH owners have standard heaters?
Old Oct 27, 2005 | 04:47 PM
xcel's Avatar
Hi Jdenenberg:
___Yes, a block heater can significantly reduce your warm up time and increase your FE over a short distance vs. not having one.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Old Oct 28, 2005 | 03:42 PM
Schwa's Avatar
Block heaters do not come standard in this part of Canada, but it's pretty mild in the south west, probably varies region to region. I've had a few used cars that had block heaters in them, so they are still a popular accessory around here since it does get reasonably cold for a few months.
chaunceyjb
Aug 17, 2011 01:42 PM
bfrank
Jun 28, 2010 02:49 PM
RazzMaTazz
13
Mar 3, 2009 06:27 PM
pdqgp
Jan 22, 2008 05:37 AM
JOE540CI
Aug 18, 2006 05:05 AM
