VCS And Multiple Dash Lights
Old Aug 9, 2023 | 11:31 AM
Chuckybost's Avatar
Default Re: VCS And Multiple Dash Lights
S Keith,
I have a 2014.5 Camry hybrid and P3027 came back after replacing 34 individual batteries, cooling fan and the drive motor battery voltage sensor. All battery were tested and voltage range from 7.76 to 7.81. Cleaned all copper jumpers and connections with Brassco and wipe down with alcohol afterward. Car ran nice for a couple of days after 30 miles, triangle waring light is back with check hybrid system.
Do you have any other through what may be wrong.
Chucky
Old Aug 9, 2023 | 11:41 AM
Originally Posted by Chuckybost
S Keith,
Chucky
How were batteries tested? Measuring voltage on a module is no more meaningful than checking tire pressure on a tire - it tells you NOTHING about the health of the module.
Since you haven't indicated any additional codes, I can only speculate that you sourced one or more bad modules.
Darby Silloway
Toyota Motor Corporation
Oct 12, 2024 10:30 PM
Greensox
Dec 19, 2019 08:36 PM
Tahoe_08
Oct 26, 2019 01:45 AM
ukrkoz
Sep 3, 2012 02:45 PM
grandpa
Nov 25, 2009 06:23 AM
