Probems with MP3/WMA Disk
Old Sep 5, 2006 | 10:03 AM
TKCamry's Avatar
2007 Toyota Camry Hybrid
Default Re: Probems with MP3/WMA Disk
Originally Posted by RCFlyer
When I insert the disc - it loads, then goes to file 1 then file 2 then file 3 up to 6 - then searchs for another disc and locks up then.... To strange....
Thanks for everyone's help so far...
Just 1 off the wall question. How many WMA songs did you put on 1 disc. The absolute max is a combined 255 songs/directories even though a std CD-r will hold many more compressed WMA songs than that. Also there is a directory structure limit of 8 levels deep. Though the owners manual recommends no more than 2 levels deep for the best results.
My WMA CD is structured with 1 root directory with no songs in it and off of that hangs 1 level of subdirectories(each subdirectory has 1 full album in it). I average just a little more than 200 songs on 1 CD, filed in about 20 subdirectories, thereby keeping me below the 255 file limit.
I have had no problems playing back multiple WMA CD's using this structure.
Old Sep 5, 2006 | 11:52 AM
RCFlyer's Avatar
Thanks for the info - I will try a setup that way - right now I am just trying 50-60 songs/files in the root directory with no subdirectory or folders.... Maybe it doesn't like them in the root directory...
Old Sep 5, 2006 | 02:47 PM
bmgoodman's Avatar
I made one disc with about 200 songs in the root folder. No subfolders. It was mostly MP3, but there were a few WMA.
Old Sep 5, 2006 | 10:00 PM
RCFlyer's Avatar
I figured it out and this may help others.... I have used Music Match in the past to rip a lot of my CD's plus I have purchased music in the WMA Format via Music Match.... Well I demo'd a conversion program and re-converted or up converted several WMA files to the latest V9 WMA - guess what - they now work.... Even though the manual says it will play V7 and v8 - it doesn't seem to - I can only get the latest V9 WMA files to play on the player in my TCH.... Now I just have to convert them all of convert them all to MP3.....
Old Sep 13, 2006 | 11:01 PM
flopshot's Avatar
OK, I ran into a similar WMA problem today, and I think I know the "real" reason which RCFlyer was able to bypass. I think the WMA player in the TCH is not DRM-compatible. So if you include any DRM-protected WMA files, the TCH stereo will not play those files. Now in my case, my stereo did not feeze-up, it simply skipped over the file and went to the next song. So now I have to upconvert my DRM-protected WMA files into non-protected version, which is what RCFLyer really did without even knowing it.
Old Sep 14, 2006 | 06:11 AM
RCFlyer's Avatar
That's a good point too flopshot! I ended up upconverting all my files to the WMA CODEC 9.1 with DBPowerAmp - but then I stripped the DRM protected files with the burn and rip process..... All my discs are now working great!
Intrus
Jul 22, 2008 08:36 AM
RCFlyer
Sep 29, 2006 10:10 AM
shoebox303
Jul 12, 2006 06:38 PM
ScarGo
Feb 8, 2006 05:28 AM
ryanh
Honda Insight
Nov 22, 2005 04:01 PM
