Override for 6.1 version of the Nav system?
Old Sep 27, 2006 | 06:43 AM
spiff72's Avatar
Default Re: Override for 6.1 version of the Nav system?
I might have to pop the DVD out of my car and see what the file structure looks like... I doubt this would work, but I am curious. I also don't have a dual layer burner (which I assume I would need to burn a "hybrid" DVD to try it).
Old Sep 27, 2006 | 08:19 AM
spam2000's Avatar
This is a fantastic idea!
Originally Posted by spiff72
Here's a crazy question...
Would it be possible for someone to take the 5.1 and 6.1 DVD's and "combine" them into one "hybrid" DVD?
In other words, could you take the map database from the 6.1 version, and the actual software from the 5.1 version, and burn your own? I know this isn't necessarily easy (since it probably isn't obvious which files are software and which ones are for the map database).
I am also curious - if you own both versions, could you swap them any time you wanted? So if I had to go somewhere that I might need the updated maps, I use 6.1, but for everyday driving (when I know where I am going), I could use the 5.1 version, and still have access to the OVERRIDE function?
Old Sep 27, 2006 | 08:43 AM
schmidtj's Avatar
Keeping Toyota Solvent
Yes it is Dual Layer and otherwise unprotected. The drive transport can read the burned media. I made a copy of 5.1 and use it as my primary media with the original in a safe place.
J
Old Sep 27, 2006 | 09:00 AM
jbollt's Avatar
J
Thanks for the info! So now we need to get someone with the 6.1v to get with you and have you burn a copy of the v6.1... then try your 5.1 in their car to see if it will work after having run the 6.1.
I also would like the updated maps, as there are lots of omissions here in Tucson, but would not like to loose the override function. LOL..such problems....such an excellent car that we have such truly insignificant issues to deal with.
Old Sep 29, 2006 | 09:16 AM
brennja's Avatar
I found this on the Club Lexus forum.
How to take v6.1 DVD and v5.1 file that allows the override and burn a new DVD with 6.1 maps and override fature.
http://www.clublexus.com/forums/show...ation+override
Old Sep 29, 2006 | 10:28 AM
stevenvillatoro's Avatar
Arrow Re: Override for 6.1 version of the Nav system?
I'd like to order one of those. Anyone wanna go into the dubbing business?
Old Sep 29, 2006 | 10:45 AM
  #27
schmidtj's Avatar
Except for the fact that what you are suggesting is 100% illegal I'd be interested.
If you hold a 5.1 AND 6.1 license you could probably merge them but even that might fall into the reverse engineering exclusion most EULAs have these days.
Old Sep 29, 2006 | 11:42 AM
  #28
dalerb's Avatar
Here is what the EULA syas (from the appendix of the Nav system owner's manual):
LIMITATIONS ON USE
The DATABASE is restricted for use in
the specific system for which it was
created. Except to the extent explicitly
permitted by mandatory laws, you may
not extract or re-utilize any portion of the
contents of the DATABASE, nor repro-
duce, copy, modify, adapt, translate, dis-
assemble, decompile, or reverse engi-
neer any portion of the DATABASE.
Old Sep 29, 2006 | 01:24 PM
  #29
jk110's Avatar
and don't forget to leave those tags on your mattresses...
Old Sep 29, 2006 | 01:31 PM
  #30
schmidtj's Avatar
Why? They say they can be removed by the owner.
