Override for 6.1 version of the Nav system?
Old Sep 9, 2006 | 06:53 PM
resa_80's Avatar
Waiting Patiently
Default Override for 6.1 version of the Nav system?
I know this question has been asked on other threads but there has not be a thread just for the question itself, so I figured I would start one so someone might see it easier who might know the answer…Is there an override function for the 6.1 version of the Navigation system so other people can use the maps and phone book when the car is in use? Can someone help?
Old Sep 14, 2006 | 07:56 AM
klynch's Avatar
Default Re: Override for 6.1 version of the Nav system?
I just picked up my TCH last week...how do you know which version of the NAV system you have?
Old Sep 14, 2006 | 02:33 PM
lovekills's Avatar
If you press Menu side button (I believe), at the top of your screen you will see a "Map DVD" button. If you press that you get info about your version. Also, it may be on the DVD itself.
Old Sep 14, 2006 | 02:46 PM
dalerb's Avatar
Just be sure you aren't moving. This is one more thing that's blocked while the car is in motion.
Old Sep 14, 2006 | 09:36 PM
BlueCam's Avatar
I'm with you resa_80!
I will look into it at other sites and let you know if I find anything.
Update!
Someone in the Tundra Solutions website has just stated...
"The access to the engineering screens have been removed. Users will no longer be able to override the safety features or modify the regions."
I will keep looking though in case this incorrect.
Old Sep 14, 2006 | 11:24 PM
agnosto's Avatar
Has anybody used the 2007 TCH DVD NAV MAP with DATA ver.06.1 or later in another vehicle (i.e 2006 Sienna) that has DATA ver.05.1 ?? I would assume it will work, but I was wondering...
Old Sep 15, 2006 | 06:27 AM
resa_80's Avatar
Waiting Patiently
Thanks BlueCam !
Old Sep 15, 2006 | 08:41 AM
klynch's Avatar
Thanks, lovekills. I found that I have version 5.1 and am now wondering what data/functionality I might be missing. I thought since I just took delivery last week that I might have the newer version.
Old Sep 15, 2006 | 09:16 AM
schmidtj's Avatar
Keeping Toyota Solvent
There are Hi-Res and Lo-Res NAV systems. The '04 and '05 Prius' were Lo-Res the '07 Camry's are Hi-Res. No clue what the Sienna is. Are the DVD's the same?
Old Sep 23, 2006 | 07:30 PM
rjg7872's Avatar
I don't have the Nav Sysytem, however after doing some reading I came across two methods in starting the diagnostic mode.
Method 1
-Start the Engine
-While pressing and holding the "info" switch, opperate the light controll switch: OFF... Turn ON... Turn OFF... Turn ON...Turn OFF... Turn ON... Turn OFF.
Method 2
-Start the Engine
-From the dispaly quality adjustment screen, touch the following corners of the screen in the follwoing order: Upper left, Lower left, Upper left, Lower Left, Upper Left, Lower Left.
I'd love to know if either of these methods work.
