Nitrogen?????
Old Aug 31, 2006 | 12:45 PM
kluken's Avatar
Default Re: Nitrogen?????
Originally Posted by clipper
Again.... if all of modern airliners use 'N2' tires -- Has to be an economic and safety reason.
When I get a fleet of several hundred ton aircraft, I guess I'll worry about it then. I think Nitrogen in car tires, is just a bit extreme and wonder if the payoff is there. An aircraft is generating many more times the stress, pressure and heat on the tires than a passenger car. I even question my own use of Synthetic oil as I never keep a car anywhere near 100K so the extra cost for better wear protection and a slight increase in MPG does nto seem worth it, so I can understand where the Nitrogen camp is coming from.
Old Aug 31, 2006 | 06:37 PM
Orcrone's Avatar
A car is carrying a little over 4000 pounds when loaded with passengers and cargo. It's generally moving at under 100 mph. A plane weighs significantly more and is landing and taking off at much higher speeds. What has economic and safey advantages for one application does not necessarily apply to a different application.
H2O Doctor
30
Aug 15, 2006 05:59 AM
dsusskind
Aug 13, 2006 07:40 AM
ppgroup
Jun 14, 2006 08:23 PM
team_venture
22
Nov 13, 2005 08:50 AM
newgreenie
Oct 24, 2005 01:00 PM
