Nav DVD ver.8.1 gen5
Old May 8, 2009 | 05:25 PM
  #31
crasher's Avatar
Default Re: Nav DVD ver.8.1 gen5
Originally Posted by ajay71
Can this hybrid be used on a Lexus RX 350 2007 Model that came with Gen 5 v 6.1 ?
Thanks in advance!
AJ
Yes
I used it on 2007 RX 350
Old May 9, 2009 | 10:21 AM
  #32
spgdxb's Avatar
Originally Posted by crasher
Eject the existing disk.
Open the fuse box under the hood.
Pull out fuse for radio1 (fuse map is on the cover) for about 1 minute.
Put back every thing together. Next time you start, it will say disk missing.
Insert new DVD, you are done.
You will also lose all preset for radio.
I did the above steps. When I turned on the car it said, DVD missing. So I put in the new disc that I burned. But it won't load. Doesn't do anything. So I popped in the old disc and it picked it up. After that I checked the presets and they were not lost..they were all still there.
I used a Verbatim DVD+R DL to burn the file. Any ideas?
Old May 9, 2009 | 10:32 AM
  #33
jpezz's Avatar
2009TCH w/NAV bought 4/08
First, the steps are only necessary to make the system pick up the 5.1 setup info. To just test a new DVD, just insert it. Only when you know it works and you want to go backwards in settings (use the 5.1 instead of a newer one), is it necessary to do the power thing.
As far as your DVD is concerned, it seems to be a matter of which software, which DVD writer, and which brand of DVD as well as a perfect file burned perfectly. You might do what I did - get someone who has been successful to make the DVD for you.
Old May 9, 2009 | 11:35 AM
  #34
spgdxb's Avatar
Well, I downloaded the torrent that says it it ver 8.1 with 5.1 kwi file. I used imgburn to write the DVD. My DVD writer is the one that come with my Toshiba Satellite laptop.
I wouldn't mind getting it from someone who's made it, I just would like to figure out why this one ain't working!!
Old May 9, 2009 | 02:02 PM
  #35
zebrajeb's Avatar
Well, I've not had any luck - technologically challenged I guess. I'd be very grateful if someone could make on for me!
John
Old May 9, 2009 | 04:41 PM
  #36
spgdxb's Avatar
Me too..please PM me if you have a copy of the DVD already made. Thanks
Old May 9, 2009 | 09:43 PM
  #37
bkushner's Avatar
There is a 8.1 torrent without hybrid out there but i can't get it to work in my car. It loads up but then I get an error message saying it's not a dvd . Burned 4 times so far. The hybrid torrent worked for me though.
Old May 12, 2009 | 05:40 PM
  #38
Scooters's Avatar
A *ahem* friend told me that the Hybrid disk works just fine!
Old May 13, 2009 | 06:36 PM
  #39
markogb's Avatar
Unhappy Re: Nav DVD ver.8.1 gen5
I had the same problem, did yo you fix it?
Old May 13, 2009 | 07:29 PM
  #40
spiff72's Avatar
I found the non hybrid 8.1 iso image, and burned it directly with Toast on my Mac, and it worked fine.
I then tried burning a DVD with Toast with the 5.1 "LOADING.KWI" file, and it wouldn't work in the nav system (it didn't recognize it as a valid DVD).
I ended up examining the iso image of the non hybrid dvd with ImgBurn under Windows XP (running as a virtual machine in VMWare Fusion), and noted what kind of filesystem it used. It was ISO9660 + Joliet + UDF, UDF revision 1.02.
So I then tried writing files (swapping out the firmware file for the 5.1 version) to a DVD using ImgBurn and under the Options tab, I chose the options mentioned above. This resulted in a successful burn that was recognized by the Nav system on my Camry.
I ended up using ImgBurn because I didn't know how to be sure what settings Toast was using on the Mac.
Maybe this will help those of you struggling with getting this to work.
Good luck!
