My car wont start
Old Oct 26, 2020 | 06:06 AM
rembossy's Avatar
Default My car wont start
My car a 2007 Toyota Camry Hybrid was showing check hybrid so i went to the trunk and removed the orange color fuse attached to the hybrid battery and fixed it back although i did not remove the terminal heads of the 12v battery. I got into the car and tried starting it but it wont start and i started it before i pulled the orange color fuse in the hybrid battery and put it back. What can i do pls?
Old Oct 26, 2020 | 12:37 PM
Default Re: My car wont start
When you reinstalled the orange safety plug, you did not install it correctly. After rotating the lever, you did not slide it into the locked position.
Note that removing the safety plug does nothing for "resetting" the system. The only time the safety plug should be removed is when working on the HV system.
You need to do #3 in reverse.
RKBrumbelow
Sep 10, 2020 09:34 AM
Patmyers
Apr 21, 2020 05:56 PM
egon10psi
May 30, 2018 06:10 AM
m.abuhamdah
Lexus GS 450h
Jun 23, 2011 09:17 AM
cephraim
Sep 26, 2008 10:08 AM
