List of pertinent TSB's
Old Mar 19, 2008 | 01:16 PM
  #101
SPL's Avatar
SPL
Default CDN_TSB2651(Rev) = TSB_EL015-06 - Smart Key Specifications
Updated and somewhat clearer statements about the transmissions that take place from the car to the fob.
Stan
Old Mar 19, 2008 | 01:21 PM
  #102
SPL's Avatar
SPL
Default CDN_TSB2663(Rev) = TSB_BR007-07 - Rear Brake Squeak and/or Premature Pad Wear
The revised rear brake squeak TSB with newly re-designed pads, etc.
Stan
Old Mar 19, 2008 | 01:27 PM
  #103
SPL's Avatar
SPL
Default CDN_TSB2692 = TSB_EG060-06 - HV ECU Software Update: M.I.L. "ON" DTC P0A84
NiMH battery cooling fan ECU software update to correct a possible error indication. I haven't experienced this problem, but had the software update done anyway as a preventative measure.
Stan
Old Mar 19, 2008 | 01:31 PM
  #104
SPL's Avatar
SPL
Default CDN_TSB2757 = TSB_NV005-07 - Shifter Trim Squeak Noise
The TSB for the endemic "cricket noise" in 2007 models, from the front center console around the shifter.
Stan
Old Mar 19, 2008 | 02:01 PM
  #105
nash's Avatar
Default Re: List of pertinent TSB's
Thank you SPL! Does anyone have this TSB?
AU004-07 AUG 07 Audio System - Noise When Using An External Device
Alldata has a listing of Camry Hybrid TSBs
Old Mar 19, 2008 | 04:45 PM
  #106
spiff72's Avatar
Yes I have had this done. I think they replaced the port itself, and installed an in-line filter.
It worked like a charm for the issues I had with the Harman Kardon Drive+Play iPod interface.
Old Mar 20, 2008 | 06:20 AM
  #107
SPL's Avatar
SPL
I have 6 more TSBs to upload, but the system wouldn't accept any more of them after the 8 that I successfully uploaded yesterday. It wouldn't accept any more PDF file uploads this morning either! Is there a daily maximum combined file upload size? None of these PDFs exceeds 2 Mbytes in size. One of them is indeed the "Noise When Using an External Device" TSB that you are interested in! So I'd like to post it ASAP.
Stan
Old Mar 21, 2008 | 08:52 AM
  #108
SPL's Avatar
SPL
Default CDN_TSB2810 = TSB_AU004-07 - Noise from Auxiliary Port with External Device
New auxiliary socket and in-line noise filter fitted to prevent noise occurring when using 12-V power to power auxiliary device.
Stan
Old Mar 21, 2008 | 08:58 AM
  #109
SPL's Avatar
SPL
Default CDN_TSB2828 - Absorbed Glass Mat (AGM) Battery Information
Gives a comparison of some of the characteristics of AGM vs flooded-cell lead-acid batteries. The TCH's 12-V battery is an AGM type.
Stan
Old Mar 21, 2008 | 09:04 AM
  #110
SPL's Avatar
SPL
Default CDN_TSB2938 - Exterior Color and Scratch Resistant and Anti-Acid Paint
The "Polishing Tips" are relevant to those with scratch marks they wish to remove from their car's paint surface.
Stan
