LED turn signals
Old Sep 14, 2007 | 12:57 PM
mikieboyblue's Avatar
Default Re: LED turn signals
Originally Posted by Squint
Unfortunately, to do an HID retrofit, the halogen projector has to be replaced with an HID projector and that requires cracking the housing open.
I thought since our headlights use a projector that you did not need to do anything other than snag a ballast for the HIDs.
Old Sep 14, 2007 | 01:56 PM
Squint's Avatar
Malcontent
Compared to other halogen projectors, the Camry's produces acceptable results if you just put in an HID kit. But you get much better results using an HID projector. Much better.
Old Sep 14, 2007 | 01:59 PM
n8kwx's Avatar
Originally Posted by David Price
Silvertch: Here is a link to the LED bulbs:
http://www.xtralights.com/index.asp?...S&Category=156
LEDs are not "'bulbs".
A light bulb radiates light more of less evenly over an entire sphere (except for the base of course). Also known as a "point" source.
What most people call LEDs (the LED die mounted in a housing) emit light directionally.
The turn signal fixtures in the car are designed for a "point source" light. If you put a LED "bulb" in them, the fixture likely won't radiate light correctly. This could be a safety hazzard.
The TCH LED taillights work properly because they were designed for LEDs.
Same things with HID headlights. The original reflectors may not aim light properly with a "retrofit" kit. And the even worse problem is that the end product does not have auto-leveling (like a good OEM HID). So you can go around blinding other drivers.
Old Sep 14, 2007 | 02:35 PM
Interesting. So if I put HIDs in with out a new projector the reflectors would not work correctly? I don't mean to hijack the thread but I absolutely HATE the headlights on this car. I can barely drive around areas that have poor street lights where the headlight do not penetrate enough. I also feel the light does not extend nearly as far out as I would like. In addition, people are always flashing me, far more than with my truck where the lights were quite hight up.
Old Sep 14, 2007 | 03:34 PM
David Price's Avatar
Happy 07 TCH Owner
n8kwx: If you check the link you will find that the LED's are called bulbs because they replace bulbs in cars and trucks.
Old Sep 14, 2007 | 05:18 PM
crasher's Avatar
Arent the rear lights already LED in TCH?
Old Sep 14, 2007 | 05:27 PM
Happy 07 TCH Owner
As far as I know, only the running & brake lights are LED's.
Old Sep 15, 2007 | 04:09 AM
Squint's Avatar
Malcontent
I think it'll be an improvement over the stock lighting but it won't be nearly as good as HID bulbs in an HID projector. The latter is as good or better than if the car was manufactured with HIDs. In many cases, they're better because you can cherry pick the components and end up with better lenses and projectors than what most auto manufacturers use.
Here's one of many threads comparing kits to retrofits:
http://www.hidplanet.com/forums/view...t=retrofit+kit
You have to register but there's a wealth of lighting information at that site including sub-forums for halogens and LEDs.
Old Sep 16, 2007 | 08:10 PM
n8kwx's Avatar
I did check the link. I also explained why those LEDs DON'T replace bulbs in cars and trucks. Most LEDs cannot be dropped into incandescent fixtures and still meet DOT standards.
Those LED replacements that I saw will not shine much light to the sides of the car. That can be a safety issue.
If you want to put yourself to sleep some night look up DOT standards for vehicle lighting. They have very detailed specifications as to how much light needs to go where.
A few years ago the DOT forced importers to recall a lot of LED lights as they don't meet the proper lighting standards. Be careful what you buy on eBay. 99% is cheap underengineered Chinese stuff.
As for HID headlights check out the difference between an Acura HID and a Lexus HID. Acura's don't have autoleveling. Lexus does. One blinds, one does not! Please don't be an Acura!
hondarider90
Sep 27, 2014 04:28 AM
Bigkart
Jul 31, 2009 05:15 AM
mikieboyblue
Jun 26, 2009 03:47 PM
bremner19
Dec 16, 2007 09:06 AM
meerkat
Aug 3, 2007 07:56 AM
