LED turn signals
Old Sep 13, 2007 | 03:55 PM
silvertch's Avatar
Default LED turn signals
Has anyone installed LED turn signal bulbs front and rear?
Old Sep 13, 2007 | 04:54 PM
David Price's Avatar
Happy 07 TCH Owner
Default Re: LED turn signals
My understanding is that the front one's are difficult to get to. The grille, bumper, and other things have to be removed in order to get to them. Not sure how to get to the rear one's.
Old Sep 13, 2007 | 10:46 PM
Tideland Prius's Avatar
The rear ones should be accessible via a rear plastic cover in the trunk.
Old Sep 14, 2007 | 03:42 AM
Squint's Avatar
Malcontent
The headlight units are glued shut so you would probably have to bake them in an oven and then pry them open. That's what you have to do if you want to do an HID retrofit (not a kit).
Old Sep 14, 2007 | 05:37 AM
mikieboyblue's Avatar
Jeez, can't they just use a screw? They sure do make things purposely difficult.
Old Sep 14, 2007 | 08:42 AM
SPL's Avatar
SPL
The lamp housing may be glued together, but the bulbs (including the turn-signal bulbs) unplug from the housing. The only difficulty is getting access to the turn- and side-marker bulbs — one has to remove the bumper to do so.
Stan
Old Sep 14, 2007 | 09:09 AM
Squint's Avatar
Malcontent
Unfortunately, to do an HID retrofit, the halogen projector has to be replaced with an HID projector and that requires cracking the housing open.
I haven't looked into LED turn signals that much because I'm not planning on changing mine but it seems that to match the brightness of regular bulbs, an array of LEDs must be used. That often entails circuit boards so it's not going to be a drop-in replacement for the existing bulb and cracking the headlight housing open may be necessary.
Old Sep 14, 2007 | 10:40 AM
abward's Avatar
I guess I am missing something....why change them if they are working ok?
Old Sep 14, 2007 | 11:20 AM
Happy 07 TCH Owner
Silvertch: Here is a link to the LED bulbs:
http://www.xtralights.com/index.asp?...S&Category=156
Old Sep 14, 2007 | 12:55 PM
Stan
Even worse!
