How to set DRL off wihtout going to the dealer
Old May 26, 2008 | 11:37 PM
bedrock8x's Avatar
Default How to set DRL off wihtout going to the dealer
I like to set the DRL off so that I can use the AUTO to turn on the head lights at dawn without DRL on. I don't have time to take it to the dealer.
What is the procedure to do this?
Old May 27, 2008 | 06:30 AM
mikieboyblue's Avatar
Default Re: How to set DRL off wihtout going to the dealer
As far as I know, you don't have a choice (without spending quite a bit of money). What you could do is manually turn on the headlights -- of course you knew that already.
Old May 27, 2008 | 05:24 PM
cngrevolution's Avatar
You might check and see if there is a relay under the hood for the DRL's that you could just pull.
Old May 28, 2008 | 12:38 AM
bedrock8x's Avatar
Unfortunately, it is a solid state switch control by the computer for DRL and high beam , no chance of removing this.
steinbock
Jul 27, 2022 01:02 PM
LEAKYTCH
Dec 6, 2007 06:15 AM
belbe
Jul 4, 2007 12:33 PM
felixdacat
Jan 30, 2007 03:07 PM
Sledge
Feb 2, 2006 11:07 PM
