Hi..I am a Noob. hi everyone. Engine Swap questions
Old Sep 1, 2016 | 10:25 AM
Kwang Kim's Avatar
Smile Hi..I am a Noob. hi everyone. Engine Swap questions
Hi.. i have 2007 camry hybrid engine 2azfxe. I found the same engine from 2010 lexus hs250h which is also 2azfxe. will i encounter any issues with swapping the engine into my camry which is same engine code? is there any slight differences if you know anything. i really appreciate your comments.
Old Sep 1, 2016 | 10:06 PM
Default Re: Hi..I am a Noob. hi everyone. Engine Swap questions
pick a thread and stick with it. Delete the other.
Old Sep 5, 2016 | 03:49 PM
ukrkoz's Avatar
Yeah, you'll have to pair engine and ECM.
Old Sep 6, 2016 | 08:56 AM
Kwang Kim's Avatar
What if i transfer all harness and sensors to the bare block from the existing engine to new one? will it still cause issues because ecm is not same? 2azfxe is just engine code. when you take off all sensors and harness, i believe its just the bare block... I am not still sure if it will still cause issues. I really appreciate your comments
Old Sep 6, 2016 | 06:56 PM
GeorgiaHybrid's Avatar
Transfer everything from your engine to the new block and you should be OK.
MarinerinVA
Dec 19, 2012 09:21 AM
JamesN
Jul 12, 2008 09:29 PM
GotIng
Nov 14, 2007 11:09 PM
dangerkitty
Jan 16, 2006 08:23 PM
DOHC
Introductions
Oct 11, 2005 06:22 AM
