Hi..I am a Noob. hi everyone. Engine Swap questions
Hi.. i have 2007 camry hybrid engine 2azfxe. I found the same engine from 2010 lexus hs250h which is also 2azfxe. will i encounter any issues with swapping the engine into my camry which is same engine code? is there any slight differences if you know anything. i really appreciate your comments.
Re: Hi..I am a Noob. hi everyone. Engine Swap questions
pick a thread and stick with it. Delete the other.
Yeah, you'll have to pair engine and ECM.
What if i transfer all harness and sensors to the bare block from the existing engine to new one? will it still cause issues because ecm is not same? 2azfxe is just engine code. when you take off all sensors and harness, i believe its just the bare block... I am not still sure if it will still cause issues. I really appreciate your comments
Transfer everything from your engine to the new block and you should be OK.
