DRL switch defeated on imported TCH!!
Old Mar 5, 2008 | 08:06 PM
  #31
steinbock's Avatar
Default Re: DRL switch defeated on imported TCH!!
I am in North Surrey, if you can come to my place, I will give you a hand with it.
(inexpensive bottle of white wine will be accepted as payment - hey, ten bucks sounds a lot better than six hundred... ).
I am a very busy person, so there might be time constrains.
Let me know by email to steinbock at shaw dot ca.
Old May 14, 2008 | 04:14 PM
  #32
boris's Avatar
Originally Posted by steinbock
Imported a TCH from San Francisco into Canada. The dealer could not figure out how to defeat the OFF switch for the DRL, so that the vehicle can pass the federal inspection (my Canadian friends will know what I mean). Flashing the TCH’s computer did not help, neither did installing a new HL switch. After the panic mode set in , I took the switch apart (nothing to it), inserted a small 5 mm piece of plastic into it and problem fixed. Free! No need to flash the computer, no need to spend $220.00 for headlight switch. Passed the federal, the provincial with flying colors, am enjoying he car right now!
Any description or photos of how to take the switch apart?
Old May 25, 2008 | 09:33 PM
  #33
cam's Avatar
cam
i am in red deer alta. just imported tch.i also would like more info on takeing the switch apart.any info would be appreciated.
Old Jun 23, 2008 | 11:54 AM
  #34
bkushner's Avatar
Has anyone figured out how to get the switch open on the stalk?
Old Jul 2, 2008 | 10:38 AM
  #35
bkushner's Avatar
Got the **** off. Just pull it hard and look into the gap, you should see a small indentation appear that I put my screwdriver into and twisted a little and the **** came off. I then put a piece of rubber in the stalk to stop the switch from rotating to drl off. Easy. Took 2 minutes. Of course the Canadian Tire 17 year old stood out front and told me to start the car. That's it. pass.
Old Jul 3, 2008 | 02:48 PM
  #36
cam's Avatar
cam
Good job.I am positive this blurb will help other canadians save some money in the future.I find this GREENHYBRID site very informative. I am on this site a lot.
Old Jul 3, 2008 | 04:02 PM
  #37
bkushner's Avatar
Yeah, next is camera installation, maybe by bestbuy, and then the block heater, by me? I like the led's in the steering wheel and stereo from toyota nation, check the camry 5/6 forum for that.
Old Sep 5, 2015 | 07:30 PM
  #38
neighborfromthesouth's Avatar
Anyone still active on this thread? I found this and was attempting to do it for my regular Camry but it seems like I would break the kno b.
Nevermind, but for anyone else in the future that comes across this thread - I opted for a different solution. I opened up the backplate and screwed on a small screw along the inside edge of the kno b to block it from being able to twist all the way.
Old Jul 27, 2022 | 01:02 PM
  #39
sarvesh's Avatar
I'm scared to yank on the **** in case I break it. Could you explain more? What's the backplate?
evois
10
May 24, 2011 05:50 AM
UWAdventurer
May 16, 2008 07:25 PM
felixdacat
Jan 30, 2007 03:07 PM
Sledge
Feb 2, 2006 11:07 PM
