Driving Condiitions
Old Sep 10, 2008 | 05:14 AM
  #31
Smilin' Jack's Avatar
Default Re: Driving Condiitions
Jimmy,
Thanks to you and your better half for service "above and beyond the call........"
You may well save me from myself and the parts desk man.
I'll keep you posted.
Jack
Old Sep 10, 2008 | 11:15 AM
  #32
SPL's Avatar
SPL
Smilin' Jack — Previous threads you might want to look at regarding block heater installation are (amongst others):
"Engine block heater installation instructions"
"Engine block heater"
By the way, the cord has a rubber cover that protects the 3-pin plug from the weather when the heater is not in use.
Stan
Old Sep 11, 2008 | 03:38 PM
  #33
Jimmy,
Stan,
Thanks again for the continued help.
I had some concern that the .....900 unit would not be right, reinforced by my memory that the picture I saw at the dealer parts desk looked more like an immersion heater than a "dry well" heated like the ...889.
I called the dealer and the confirmed that the 09 TCH application was correct.
Later I found the following picture and notes, which have allayed my fears for now:
http://www.trdparts4u.com/PD-00213-00900.aspx
The picture looked similar to the one in the ttora thread for the ...889. (Thanks, Jimmy)
And the applications included 2001-2009 Prius as well as 2002-2009 Camry 4-cyl even if not specifically TCH.
So, for now I'm happy to wait and see what comes in.
Meanwhile, I'll review the installation thread. (Thanks, Stan.)
Jack
Old Sep 11, 2008 | 03:48 PM
  #34
rburt07's Avatar
That 900 sure looks like it. I also says it fits the 2.4 4-cyl which the hybrid uses other than the Atkins cycle cam instead of the standard gas cam for the gas powered Camry.
Old Sep 13, 2008 | 09:57 AM
  #35
Droid13's Avatar
HSD Organic Interface
Originally Posted by SPL
Droid13 — I ran the cord through the lower radiator grille prior to having the dealer install the heater. This is possible to do, without breaking the plastic grille, provided you run the heater plug end of the cord through the grille from the outside, since this plug is smaller than the 3-pin mains plug at the outside end. I used cable ties to anchor the 3-pin plug firmly to the grille's slats, below the front license plate, so it's not very visible.
Stan
Just finished re-routing the cord. Fortunately I was able to squeeze the plug from the inside of the grille to the outside so I didn't have to completely reroute the cable and remove all the tie wraps the dealer put in. It was a snug fit coming out, but did so without problems...
Soleil24
17
Mar 5, 2006 07:12 PM
Jason
Apr 29, 2004 07:44 PM
Hot_Georgia_2004
Mar 7, 2004 08:54 PM
Jason
Feb 27, 2004 01:39 PM
