Dark colors bad for hybrid battery in sunlight?
Old Jun 24, 2007 | 04:50 AM
08FEH's Avatar
Default Re: Dark colors bad for hybrid battery in sunlight?
I can add a little to this post I think.
I'm not sure if the color affects the battery at all, but it sure affects the cabin temperature and the energy needed to keep the interior cool on a sunny day.
Try this test, go to ANY car dealer and ANY car model for sale on a sunny day. Pick a light colored and a dark colored car next to each other. Put your hand on each one. I was BLOWN AWAY by the difference in temperature on both cars by simply touching the roof of each. The lighter colors were just barely warm to the touch, while it was difficult to hold my hand on the same exact car with a dark color (TOO HOT).
I know this is BASIC KNOWLEDGE and not some scientific break through, but I can tell you that I never expected the difference to be as severe as I learned on that day.
Food for thought.
08FEH
Old Jun 25, 2007 | 11:55 AM
Pete4's Avatar
Of course darker car gets hotter in the sun, I had silver and red car, red car was always about 10F hotter inside when both were sitting in the sun. And it's not about something breaking down either, it's about efficiency. Hotter car will take longer to cool it and battery itself will reach higher temperature faster under the same load if it starts at higher temperature, therefore it may use ICE more often to keep the battery within operating range. Running fan in the parked car makes no sense, the hottest air is on the top, right under the window, just where the fan intake is, I would imagine battery being low inside the trunk have one of the cooler places in the whole car. Only when you drive with AC on will running fan start making sense to keep the battery cool, but that's when it needs it the most.
Old Dec 19, 2008 | 09:09 PM
SpecialAgentPrius's Avatar
I read a small blurb in the Times last week that talked about the TCH hybrid battery getting hot enough that it could start a fire. It also said not to put anything on top of the battery, like luggage and so on, again it will make the battrey hot.
Old Dec 19, 2008 | 10:07 PM
roseng's Avatar
HAPPY TCH OWNER
Originally Posted by McGyver
I wasn't too worried about the battery, but I wanted to be certain not to get a gray colored car. I had a car once that was medium gray metallic...
I got hit in that car 3 times in ten years. Each time it happened the other driver said exactly the same thing: "I never saw you".
After a while I figured it out. The car was the same color as the road! At dusk, or at night, or in bad weather, I simply disappeared into the background.
My last 4 cars were all brightly colored. And I haven't been hit since.
I've been driving for quite a while. Luckily, I've had very few accidents. The only one that I had that was "My Fault" was from was pulling out in front of a gray car on a cloudy/rainy day in a tree lined area. I NEVER SAW THE CAR.
My TCH is Blue Ribbon. Gray, silver, primer, whatever... it's a dangerous color.
nicst47
Jan 28, 2008 01:15 PM
drquine
Jun 23, 2006 05:41 PM
Rogstar
May 5, 2006 07:12 AM
bfranci
Mar 2, 2006 07:31 PM
tourretired
Aug 28, 2005 11:30 AM
