Air compressor
Old Oct 16, 2019 | 08:37 AM
haroldo's Avatar
Default Air compressor
I just bought an
air compressor air compressor
The instructions say
Operating Instructions:
1. Make sure the power switch is at OFF position and the vehicle engine is running.
2. Remove the dust cap from the tire valve, and then attach the air chuck to the tire valve stem, and screw onto tire’s valve stem.
3. Plug the power cord into a 12V cigarette lighter socket.
4. Press (M) button to choose the display unit. (4 units available: PSI, KPA, BAR, KG/CM). Press (-) or (+) button to set the desired pressure, and then wait until it stops flashing.
5. Turn on the power switch. The compressor will automatically stop inflating once the desired pressure is reached.
6. When the desired pressure is reached, turn OFF the power.
7. Unscrew the valve connector, place the tire valve dust cap back to the tire & disconnect the power cord from a 12V cigarette lighter socket.
Just wondering if there are any issues with hybrids.
Thanks!
Old Dec 30, 2019 | 04:56 PM
ausadbarc's Avatar
Default Re: Air compressor
I have filled air in my 2008 camry hybrid tyres using the 12v socket in the car
c0ugar69
Sep 9, 2010 09:49 PM
SrfCity
Jun 6, 2007 04:04 PM
Island Mariner
Feb 7, 2007 06:51 PM
