2009 TCH won't charge hv battery
Old Aug 19, 2022 | 06:27 AM
Tchaikovsky's Avatar
Default 2009 TCH won't charge hv battery
My TCH had the flashing dashboard and not starting. I replaced the 12v battery and it now will start and Ready light comes on. But the icon never shows the motor running or charging, even though the motor does turn on. The vehicle can only crawl. When camry is crawling the battery icon starts draining. When I rev the engine on parked, the battery icon drains. I was able to charge the hv battery through the fuse box back to full. And the hv battery maintained its charge overnight. I also checked the 33030 fuse for continuity and even checked its ohms and it was fine. I check other fuses in the fuse box and they were fine.
The obd2 scanner gave me these error codes
c1241
c2122
c2144
c2142
c2124
c2121
I do have my car stuck in a Toyota dealership parking lot. Not sure if they can tell me what's exactly wrong with it or more of the same.
Old Aug 19, 2022 | 10:53 AM
Default Re: 2009 TCH won't charge hv battery
All but the C1241 are for tire pressure sensor issues.
You're likely missing many, many codes. Cheap consumer code readers miss a lot.
Do you have gas in the car?
Please elaborate on how you charged the HV battery to full via the fuse box.
jeffemcguire
Aug 10, 2016 08:26 PM
lmiller8456
Jun 26, 2014 10:11 AM
sadat1914
Jul 26, 2007 01:56 PM
medicmike
Aug 26, 2006 08:12 AM
