Off Topic Politics, life, gadgets, people... gobbledygook.
Stuff I don't like and other grumblings...
Old Apr 22, 2006 | 08:41 PM
rigger's Avatar
now Insight, had an HCH
Default Re: Stuff I don't like and other grumblings...
No problemo. I've got such thick skin I might as well be a turtle.
Actually that "FULL and MILD" thing really used to get on my nerves some years back.
Originally Posted by toast64
It's called a smiley face. go on and say it... "smi-ley--face". They are conveniently located on the right hand side of your edit screen.
Just kiddin', rigger - couldn't resist.
Old Apr 23, 2006 | 06:15 AM
AshenGrey's Avatar
Hybrid True Believer
Originally Posted by Pravus Prime
And yet it's used by the EPA to describe the IMA and HSD systems in their graphic "tutorial" to explain how the systems work. http://www.fueleconomy.gov/feg/hybridtech.shtml
Of course, another way to think of it is this:
- Full hybrids assist a LOT at low speeds and hardly at all at highway speed.
- Mild hybrids assist a moderate amount at ANY speed.
The valve of either System really depends on how the individual user needs to drive.
Old Apr 23, 2006 | 07:16 AM
bwilson4web's Avatar
Engineering first
Talking Re: Stuff I don't like and other grumblings...
- Mock hybrids only turn off the engine when stopped.
Bob Wilson
Old Apr 23, 2006 | 10:48 AM
toast64's Avatar
I'm not a Prius/FEH owner, so I'm asking an uniformed question; what leads you to say that full hybrids assist hardly at all at highway speeds? Is it because the Prius uses a lot of battery during starts, without ICE, so they programmed it to not assist much at highway speeds? I would think with a 40 hp motor it would assist a lot, if it's programmed like the HCHII.
Old Apr 23, 2006 | 02:50 PM
Pravus Prime's Avatar
Prof. of Hybridology
Good question. With the FEH, on expressways, I'm pretty much always in "hybrid drive", that is both the electric and gas motors are contributing power. During my 80 mile expressway commute back and forth, I rarely see Engine drive with no electric support more than 2 or three times, for less than 15 seconds each time.
I tend to think of them as fundamentally different, but with the same overall idea.
IMA: A gas engine with an eletric motor to help out.
HSD: An electric motor with a gas engine to help out.
Mock: A gas engine that wishes it had an electric one to help out.
Old Apr 23, 2006 | 03:03 PM
Delta Flyer's Avatar
Banned
Default Don't Like Pie in Sky Solutions, Then Ignoring Actionable Items
I don't care for technologies such as hydrogen vehicles offered as a cure-all, then doing little to nothing with technologies currently at hand. Both GM and GWB could be more serious about hybrids and trim vehicles instead of dangling the allure of fuel cell vehicles that are years away. If you want credibility, do something now.
Concerning what the government can do now, I have a list that I'm sure others will add to (some controversial):
  1. Seriously raise the CAFE standards and include the H1 and H2
  2. Narrow the farm vehicle exemption to farmer and businessmen that use it as a workhorse - no billboard Hummers - no exemptons on luxury SUV's
  3. More incentives for windmills, residential and workplace solar energy.
  4. Require desktop computers to have more of the energy-saving features laptops do.
  5. Continue to raise the energy efficiency of home appliances and air conditioners.
  6. Require new vehicles to run on flexible fuels
  7. Surcharge on obvious macho, but gas-guzzling options such as tires oversized for that vehicle, monster trucks jacked up a couple of feet, rhino bars....
  8. Have fleets on the local, state, federal, and non-combat military level to run with alt. fuel/hybrid technology.
  9. Encourage cities to syncronize traffic lights to stay green if cruising at a constant speed.
  10. (Controversial) More nuclear plants
  11. (Also controversial) Implement "clean coal" plants.
  12. Work on reclaiming material and energy from solid waste landfills
One broadcast suggested that if Americans got 5mpg better on what they drive, we would not be complaining about gas prices now....sounds reasonable.
Old May 6, 2006 | 01:51 PM
  #27
lakedude's Avatar
Another thing I cringe when I read is that you should get a Honda if you drive on the highway and a Prius if you drive in the city. I do believe the Prius has a little advantage in the city but I don't think the Hondas have any advantage on the highway.
Old May 6, 2006 | 06:23 PM
  #28
kasia's Avatar
Java Geek
I was under the impression that Hondas get better highway mileage than the Prius? If that's the case then the 'recommendation' would be true as the Prius does get better city mileage than a civic.
I'm probably totally wrong though
Old May 7, 2006 | 07:31 PM
  #29
lakedude's Avatar
On the highway the HCHs are EPA rated at 47, 51, 51 for the gen1 CVT, MT and gen2 respectively. The gen2 Prius is rated at 51 highway so the Civics are all the same or less. Of course the Insight does better but an Insight is so much smaller a direct comparison to a Prius is not fair.
I'm a huge Honda hybird fan including the Insight but I like to be fair at the same time. Just as I don't like misinformation that makes the Prius look artifically better than the Civic the reverse is also true. The Prius deserves credit where credit is due.
Old May 10, 2006 | 06:28 AM
  #30
Banned
Default Getting Too Carried Away With Acronyms
Sometimes we forget not everybody is familiar with some of the acronyms thrown out here. For instance - what is TCH? That' probably the Toyota Camery Hybrid, but it's a guess. Occasionally spelling things out can clue the unfamiliar in.
McGyver
Dec 28, 2010 07:30 AM
mikeki
Nov 7, 2006 05:13 AM
ElectricTroy
Off Topic
Nov 16, 2004 12:50 PM
