07 TCH Changing Struts and other stuff
Old Dec 26, 2010 | 08:32 PM
McGyver's Avatar
Default 07 TCH Changing Struts and other stuff
Well this up loader made life difficult tonight. Here is a greatly reduced pdf file of the 50 pictures making up my crude strut changing documentary.
Hopefully it will be helpful to others as our cars age. Mine has 62k miles and both front struts were completely shot. The rears were weak.
If anyone wants higher resolution, let me know.
Enjoy!
File Type: pdf
Old Dec 26, 2010 | 08:59 PM
ukrkoz's Avatar
Default Re: 07 TCH Changing Struts and other stuff
very nice! thank you.
what's "rocks tcrap in bottom cushion"?
out of curiosity, why did you have to have it on four jacks? well, 2 jacks and 2 stands? instead of doing one end and moving over to the other?
also, i have noticed "taped weights do not stick to scuzz". does that mean taped weights do not stick to dirty inner rim? aren't, like someone here said, THC rims supposed to be "all taped weights"? and you have a weight on the inside rim edge?
Old Dec 27, 2010 | 02:44 AM
McGyver's Avatar
A - That would be "rocks + crap", rocks, pocket change, melted candy, cell phone parts, etc., anyone with kids will know. Now is the time to scrub it all out.
A - No. But I have a slightly pitched driveway, and I was teaching my 16 year old. The safer, the better. Plus, when delivering 154 ft/lbs of torque to the spindle, all four up is probably best.
A- Mine appear to have clamp weights for inner and tape weights for outer, including a couple that fell off due to "scuzz" (ie - dirt, oil, etc).
Old Dec 27, 2010 | 08:35 AM
ukrkoz's Avatar
gotcha. thank you.
it was in one of my posts back here, i was "reminded" that ALL TCH wheels are balanced with taped weights; that was in response to my remark that alloy wheels do not hold rim weights well. hence my curiosity.
yes, i have noticed the slope.
great info. lots, lots of work. i know, i have done this.
let me know in 2 mths how goes it. you know my experience with shock changes.
Old Dec 27, 2010 | 09:03 AM
McGyver's Avatar
oops, minor correction... The "rocks + crap under cushion" refers to the the bottom strut cushion which literally had gravel and other FOD embedded in it. Even sections of the coil spring were worn away from constant contact with this debris.
The crap found under the seat cushion was another matter and very teenage in origin.
Another thing.... my son lost one of the strut plate mount bolts which caused me to pull out the entire fender skirt to look for it. Both the fender skirt and the energy absorbing bolster at the rear of the fender are unique to the hybrid Camry. My supposition is that it is for sound deadening purposes. Nevertheless, there was several pounds of wet, rotting leaves, mud and plant matter compacted behind the bolster. I believe this to be a small design oversight that will cause problems for folks in the snow country.
Old Dec 28, 2010 | 07:30 AM
UWAdventurer's Avatar
Thanks for the PDF. Great info there.
ukrkoz
Feb 29, 2024 09:24 PM
jmistche
Jul 4, 2012 11:53 PM
Eskimonio
Feb 16, 2007 08:53 PM
lakedude
Off Topic
29
May 10, 2006 06:28 AM
ElectricTroy
Off Topic
Nov 16, 2004 12:50 PM
