View Poll Results: What tire pressure for your RXh?
30-31
0%
32-33
16.67%
34-35
16.67%
36-37
33.33%
38-39
0%
40-41
33.33%
Voters: 6. You may not vote on this poll
RXh Tire Pressure, psi
Old Jun 2, 2006 | 08:30 AM
SlvrRXh's Avatar
RX400h Enthusiast
Exclamation RXh Tire Pressure, psi
Hi all,
I wanted to know what other RXh owners are setting their tire pressure to. When I got my car from the dealer, all 4 tires were at 40psi. I thought that was kind of high since the driver's side b-pillar says 30psi. So I lowered all 4 tires to 31-32 psi. Currently I'm getting 21.5mpg (car still only has 300 miles). I'm hoping that as it breaks-in, mileage will go up. But I want to do all I can now to start getting better mpg.
So what pressure do you have in your tires? I have AWD so I'm guessing I can set an equal pressure for all 4 tires.
Also, after I lowered the pressure to 32psi, I noticed when I have my windows down that the tires sound kind of "squishy" when driving/cornering. Is that normal? I don't want the tires to wear out too fast, and I want good gas mileage. Any tips are welcome.
Old Jun 2, 2006 | 08:56 AM
jajohnson's Avatar
Happy HiHy Owner
Default Re: RXh Tire Pressure, psi
I have a 2006 HiHy, not a Lexus, but the resuls should be similar. I found that 40 PSI resulted in the best gas mileage. It is less than the maximum for the goodyear tires (44 PSI). YMMV.
Note that I initially read 40 PSI using a standard (cheap) tire gauge. When I got a digital tire gauge it read 5 PSI lower. Since adjusting tire pressure to 40PSI I suspect that it will make up for my using air conditioning, maintaining my 30 MPG average.
When I take take my first long trip (PA to FL) in July, I expect 30 MPG highway, above the 27 MPG EPA estimate. This will be despite a loaded car on the way down, but empty on the way back.
Isn't this fun?
jenlu2000
Oct 6, 2011 08:32 AM
JoeRemix
Aug 12, 2009 09:05 PM
SlvrRXh
Lexus RX 400h
Jun 4, 2006 10:37 AM
coyote
Aug 17, 2005 03:31 PM
