View Poll Results: When do you fill your RXh's gas tank?
3/8 tank
8.33%
1/4 tank
25.00%
1/8 tank
16.67%
When the gas light comes on
33.33%
After the gas light has been on a while (almost to 'E')
16.67%
Voters: 12. You may not vote on this poll
When to Fill the RXh Gas Tank
Old Jun 2, 2006 | 08:48 AM
SlvrRXh's Avatar
RX400h Enthusiast
Default When to Fill the RXh Gas Tank
So when do you fill the tank? My dealer said I should never let it go below 1/4 tank. I did that with my first tank, and got 280 miles. Sure I could've gone more miles, but I was kind of scared at how the dealer told me not to go below 1/4 tank.
I want to get input of other RXh owners on when you fill up, and why. Thanks in advace.
Old Jun 2, 2006 | 11:18 AM
nomorebenz's Avatar
Default Re: When to Fill the RXh Gas Tank
I fill up when convenient. Usually at 1/2 +-1/8.
Old Jun 2, 2006 | 02:07 PM
hsolo142's Avatar
I keep it simple. I refuel when I reach 400 miles. That's usually about 14-15 gallons. They say it's a 19.1 gallon tank. Should be safe...
Old Jun 4, 2006 | 08:44 AM
SlvrRXh's Avatar
RX400h Enthusiast
IIRC, my manual says it's a 17.2 gallon tank. Is it 19.1 with reserves?
Old Jun 4, 2006 | 10:25 AM
Seadog's Avatar
Just Say No, to more oil
I believe both the HiHy and Lexus are 17.x gallons - When my HiHy gas light came on and I filled it up it took just a hair over 15 gallons. I believe the light comes on when you are down to 2 gallons.
Old Jun 4, 2006 | 10:29 AM
hsolo142's Avatar
Jeff,
Okay, looks like I've reported some incorrect information. Toyota's website reports a fuel capacity for the regular gas-version of the Highlander at 19.1 gallons. There is a very subtle bug in their website. If you go to www.toyota.com, click on Hybrids > Highlander Hybrids > Specifications, you will actually get the gas vers specs which can only realize by the small title "Highlander (Gas)".
If you then click on the "Highland Hybrid" picture in the upper right again, you get the HiHy specs... which reports a fuel capacity of 17.2 gallolns, same as the Lx400h.
Grrr. My bad. I also verified in the specification section of the my HiHy owner's manual that the tank capacity for the HiHy is 17.2 gallons...
-Han-
Old Jun 4, 2006 | 10:37 AM
Seadog's Avatar
Originally Posted by hsolo142
Jeff,
Sorry, looks like I assumed too much about the similarities between the Lexus 400h and the HiHy. The Lexus site does report a fuel capacity of 17.2 gallons for the Lx400h, whereas the Toyota site reports a fuel capacity for the HiHy of 19.1 gallons.
My fuel gauge in my HiHy is usually around the last tick at about 15.5 gallons. It does state in the owner's manual that "It is a good idea to keep the tank over 1/4 full." However, what that means is open to question. I also remember reading somewhere (forgot the source) that it was bad to run it down near this 19.1 gallon limit because it may have negative effects on the hybrid system...
-Han-
My HiHy owners manual states the tank capacity is 17.2 gallons - and with my experience of the idiot light coming on and doing a fillup, only a little over 15 gallons go back in..... . Although, I normally try to fill it up when it reaches 1/4 tank.
SlvrRXh
Lexus RX 400h
Jun 2, 2006 08:56 AM
haladek
Toyota Highlander Hybrid
Dec 9, 2005 10:53 AM
