3rd trophy!!
Old Nov 8, 2009 | 12:13 PM
mac1520's Avatar
Default Re: 3rd trophy!!
Changing the oil will not reset the trophy system. Here's what the owners manual says:
The following procedure clears all
leaves and your lifetime points.
This procedure must be followed exactly.
As you progress to a higher level, the
system monitors your driving style
more strictly. As a result, you must
further refine your driving style to
continue to move up to the next level.
Turn the ignition switch to the ON
(II) position. Confirm that the ECON
mode is OFF. If it is OFF, proceed to
step 1. Do run the engine.
The following are some of the
conditions that may effect your
score:
Extremely high or low ambient
temperature
Inconsistent acceleration use, such
as pumping the pedal repeatedly
within a short period of time
Frequent use of the climate
control system
Short distance trips
If the ECONmode is on, press and
release the ECONbutton to turn it
off. You also need to turn the ignition
switch off.
(II) position again. Do run the
engine.
Press and release the brake pedal
at least two times.
The ambient meter color changes from blue to
green .
Complete the following steps within
30 seconds:
changes only if the multiinformation
display’s meter color change setting is on.
Press and release the ECON
button two times (ECON mode
comes on, then goes off).
The ambient meter color goes off, and
the accumulated data is cleared.
LOCK (0) position.
I just got mine the other day, I'll see if I can reset.
Mike
Old Nov 10, 2009 | 07:29 AM
MrEWorm's Avatar
I'll try and see it it resets the trophy gizmo. Thanks for doing the research on this.
Old Nov 10, 2009 | 08:02 AM
mrkcohen's Avatar
Moderator
Thanks for finding this Mac. The PDF didn't cut and paste very well so I have cleaned it up so it's easier to read. The procedure is on page 310 of the owners manual.
The following procedure clears all leaves and your lifetime points. This procedure must be followed exactly.
Turn the ignition switch to the ON (II) position. Confirm that the ECON mode is OFF. If it is OFF, proceed to step 1. Do NOT run the engine.
If the ECON mode is on, press and release the ECON button to turn it off. You also need to turn the ignition switch off. Turn the ignition switch to the ON (II) position again. Do NOT run the engine.
Complete the following steps within 30 seconds:
1. Press and release the brake pedal at least two times. The ambient meter color changes from blue to green*.
*The ambient meter color changes only if the multiinformation display’s meter color change setting is on. (See page 103.)
2. Press and release the ECON button two times (ECON mode comes on, then goes off). The ambient meter color goes off, and the accumulated data is cleared.
3. Turn the ignition switch to the LOCK (0) position.
I am going to try this myself. Thanks again.
Old Nov 10, 2009 | 02:27 PM
MrEWorm's Avatar
I have now reset my trophy bar. It seems strange to have the saplings again........
Old Nov 10, 2009 | 07:38 PM
mac1520's Avatar
Thanks for the assist mrk! Glad to see it worked.
arbittan
Honda Insight II
Jun 29, 2009 05:21 AM
GunnyE7T
Feb 16, 2007 04:40 AM
CamelFilters
Mar 21, 2006 06:07 PM
lakedude
Off Topic
Mar 3, 2006 09:40 PM
Mikeyt758
Feb 8, 2006 08:36 AM
