Honda Admits to Premature Battery Deteriation
Old Apr 10, 2006 | 12:32 PM
Hondasucks's Avatar
Default Honda Admits to Premature Battery Deteriation
Well, I decided to start a new post so that it is more focused for site searching on this website, please lock the OTHER post and keep this one open
Taken from an internal service bulletin dated March 31, 2006
"WARRENTY EXTENSION: IMA BATTERY PREMATURE DETERIORATION DTC P1447 OR 1449
The IMA battery may be susceptible to premature deterioration in which case the MIL will be illuminated and DTC P1447 or P1449 can be retrieved. The warranty period on the IMA battery is extended to 10 years or 240,000km, whichever comes first.
AFFECTED VEHICLES:
200-2004 .............. ALL"
When my main computer is up and running I will scan this and post it for you to read and download
Other interesting information in service bulletins I have recieved
Honda Canada INTERNAL bulletins
-Pass. Side Airbag recall
-Window Down fuction
-EVAP bypass solenoid valve
these i will also scan and post
-EMISSIONS RECALL NOT CORRECTLY IDENTIFING THE LAF 02 SENSOR
Old Apr 10, 2006 | 03:51 PM
Hondasucks's Avatar
Default Re: Honda Admits to Premature Battery Deteriation
Here it is
Old Apr 11, 2006 | 04:50 PM
foo monkey's Avatar
Questions:
1: How can you tell if your battery is deteriorating, ahead of schedule?
2: Only 1.2 hours to replace the battery pack? (rhetorical.)
Old Apr 11, 2006 | 05:32 PM
tbaleno's Avatar
1.2 hours is plenty of time to replace it. They can probably do it in less that 45 minutes maybe even less. You just have to remove the back seat and unbolt a few bolts.
Nice of honda to extend the warranty to make sure they get rid of all the bad packs. Kudos to honda for taking the extra step for its customers.
Old Apr 11, 2006 | 05:36 PM
Hondasucks's Avatar
Originally Posted by foo monkey
Questions:
Unless there is a check engine light, it has been my experience that you are SOL. It took almost a year for mine to illuminate from first failure. Almost ment the difference between Warrenty and No warrenty (2000km)
Old Apr 12, 2006 | 07:02 PM
rigger's Avatar
now Insight, had an HCH
tbaleno - Where's this "back seat" you make mention of?
HONDASUCKS - Thanks for that update. It sounds as though **YOU** may have made a difference. I know my battery pack's days are numbered but I've been having frequent recals for 15,000 miles now. I wonder if/when they'll make this happen in the US.
Old Apr 13, 2006 | 06:08 AM
Hondasucks's Avatar
hello rigger, check out this thread
https://www.greenhybrid.com/discuss/...6627#post56627
Guss
May 4, 2012 12:31 AM
ndabunka
Toyota Highlander Hybrid
19
Feb 4, 2010 11:09 PM
Tim K
Feb 19, 2007 04:11 PM
GeekGal
Jun 3, 2006 08:38 AM
Sledge
May 26, 2006 07:13 AM
